Please read this , Brake Problems....
Old Feb 1, 2002 | 05:48 PM
mcsetl's Avatar
3rd Gear
Angry Please read this , Brake Problems....
Please let me know if you have the same "Clicking Noises" from your Brake system when you apply the brakes the first time after chnaging the direction from D to R or R to D.
This noise started after I put 3000 miles on my Tl (2001 W/N).
Dealer and Customer service telling me that this is the Characteristcs of Acura's brake (B. F. S.).After 5 times trying unsecsessfully to repair the problem.
I am having appointment next week with an Attorney to discuss this issue.
I need some feed back on this .
Please let me know if you the same problem or not.
Thanks.
Old Feb 1, 2002 | 05:59 PM
dnd2984's Avatar
Is it loud? Are u paranoid like me? does it affect braking?
Welll Once a week I drive wit all the windows up, AC and radio off and listen for stuff like that. Im gonna see if my TL does the same thing.
Old Feb 1, 2002 | 06:40 PM
mcsetl's Avatar
3rd Gear
It is loud enough to hear (of course no Stereo on). It sounds like the clicking noise from transmission when you go from P to R or wise versa.
Old Feb 1, 2002 | 06:43 PM
Jens
Guest
Posts: n/a
A minor click from your brakes is normal when you first change directions and apply the brakes the first time.here is what that noise is:your brake pads sit in a part commonly called a "yoke".As you know brakes in time will wear which means in order to continue to function they must always be in contact with the brake rotor.Well in order to allow this to happen the brake pads are slightly smaller than the yoke they rest in in.it is this small difference in size allows the pads to slide in towards the rotor as they wear but it can also cause the slight click you hear.You see when you change direction the brake pads shift slightly in the yoke and the result is a click.Acura published a service bulletin or service news about this quite some time ago.
Now mind you I cannot hear your click via the internet so it may be you are experiencing something different are your brakes functioning normally other than that?
I have had some success in the past applying a small amount of brake pad grease to the ears of the brake pads.This seems to get rid of the noise for the most part .Jens
Old Feb 1, 2002 | 07:13 PM
VTEC's Avatar
yea. i had that sound too. it happen in the moring when i'm going foward after i back-up form my drive-way. it is " ker " i can heard it when my windows are down and no radio.
Old Feb 1, 2002 | 08:35 PM
TL's Avatar
TL
My brakes often squeak a little when I first drive the TL in the morning (ie: when I apply the brakes while backing out of the garage). It goes away after a little driving. Is that normal?
Old Feb 2, 2002 | 03:19 AM
prlcivic's Avatar
that click when changing directions is normal characteristics of the brakes. jens is right. if you really want to pin point the noise. stuff some paper or something simular between the pad tabs and caliper. test drive if it goes away then its the pads. its called brake pad shift. but if it is still there then have it checked out. i wouldnt waste you time with an attorney. its a real common complaint. also to add to jens' comment, its also for heat expansion.
mada51589
Jan 9, 2025 04:40 PM
rklatzkin
Sep 23, 2015 04:08 PM
jaimbot
Sep 17, 2015 09:25 AM
jliu6789
Sep 8, 2015 08:02 PM
asahrts
Sep 4, 2015 05:55 PM
