Please help if you can
Old Mar 8, 2017 | 01:49 AM
NeedassistanceASAP's Avatar
My 2001 TL wouldnt start, I just replaced the battery a few months ago, but I jumped it to be sure, still didnt start, but my heater, stereo and headlights all work normally. could it be the starter? alternator? any help is much appreciated thank you!
Old Mar 8, 2017 | 06:09 AM
Typically starter if you have ruled out battery. The main relay is also a common culprit so you can check that before replacing the starter
Old Mar 8, 2017 | 08:59 AM
When I try to turn it over, it doesnt even try to turn over. no clicking noise ot anything. does that narrow it down any further?
Old Mar 8, 2017 | 09:01 AM
do you hear the fuel pump prime? sounds like it may be the main relay https://acurazine.com/forums/2g-tl-p...-relay-931252/
Old Mar 8, 2017 | 12:03 PM
Karanx7's Avatar
Unregistered Member
So the starter isn't turning. The question is whether the starter is bad, or the main relay. You can easily test this by seeing if the starter is getting power when you try to crank.
Or you can just fix the cheaper option first, and replace the main relay.
Old Mar 8, 2017 | 01:47 PM
SuperGreg's Avatar
Have you checked all the wires going to the starter?
