A-Pillar Gauge Mount
Old Jun 18, 2003 | 12:48 PM
scalbert's Avatar
I posted on the CL forum last weekend about this but now that I have confirmed that the basic molds for the CL an TL A-Pillar trim are nearly identical, I decided to post here.
But first a couple of questions regarding the trim on the TL. The trim piece for the CL and TL are identical in shape and size, etc. However, the TL I looked at had a cloth covering on the A-Pillar trim piece. Is this the case for all TL's??
If so, would the TL owners interested in this accept a plastic A-Pillar mount??
Now for the rest of the which I post on ACL:
Although I did not plan on adding this to my CL it seems that it may now be appropriate.
So who wants a true and complete A-Pilar gauge mount?? It would be similar to what is available for the NSX:
This would be a two gauge pod matching the factory A-Pillar trim piece. I need at least twenty people and I will give my stock piece for the mold. Price would be about $45.
I am going ahead with the arrangements and sending in my stock piece but I wanted to throw out this offer to TL owners as well.
Old Jun 18, 2003 | 01:08 PM
hzm82's Avatar
Well its only cloth covering on 2002+ TL I believe. 1999-2001 are plastic, so its all good for us guys. I'm not familar with the gauge pods, but I seen it on my friend's car. So rather then ask them and have them think I'm stupid. I rather ask you guys and have you guys think I'm stupid. What readings does the two gauge pods give?
Old Jun 18, 2003 | 01:16 PM
scalbert's Avatar
This is just a plastic trim peice which replaces the stock unit. It does not contain the gauges; you would need to purchase then seperate. What could you monitor is up to you. Things such as Transmission Oil Temperature, Oil Pressure, etc. come to mind for you automatic TL guys. But there are many other parameters.
I am doing this to add a boost and fuel pressure gauges for my blown CL-S6. I had not planned on adding any gauges but with a recent issue with the FPR I would feel more comfortable monitoring fuel pressure at all times.
BTW, thanks for the update on the '02+ TL having the cloth covering.
Old Jun 18, 2003 | 02:00 PM
TLlikeWHOA's Avatar
scalbert....im in let me kno what i need to do
-Eric
Old Jun 18, 2003 | 02:03 PM
scalbert's Avatar
Once completed they will be on the manufacturers website:
Lotek
Old Jun 18, 2003 | 03:05 PM
TopGum's Avatar
I've been looking for this! I'm in!
Old Jun 18, 2003 | 03:33 PM
Red Hot TL's Avatar
Wow, blown CL-S6... really nice!
I might get one.
Old Jun 22, 2003 | 02:30 AM
VTECRRR's Avatar
i went to lotek
Lotek
i bought a 3 gauge a-pillar for a 99-02 honda accord in tan color! adding autometer lunar gauges for tranny temp, voltage meter, and N2O pressure! i'll have it this week and let you know if everything is
Old Jun 22, 2003 | 08:54 AM
Paulie's Avatar
8th Gear
does the 2002 accord triple pod fit a acura 2002 tl tye s... is it the same part...
paulie
Pbogdanski@aol.com
Old Jun 22, 2003 | 05:33 PM
VTECRRR's Avatar
Exclamation all those parts are the same!
accord and tl have many interchangeables. knobs, switches, etc. i basically took a shot on the honda pillar fitting the 99 tl knowing this about honda. it looks the same? i can also mod it if need be. as far as the type-s, call the dealer and ask if the pillar is the same as in non-type-s. i'm sure it's identical!
Old Jun 22, 2003 | 05:49 PM
fastcarz3's Avatar
hey
i might be interested what color does it come in cause i got a black interior
Old Jun 22, 2003 | 06:56 PM
badazzTL's Avatar
Peach Tea
im interested, they look so kewl
Old Jun 23, 2003 | 05:02 PM
Paulie's Avatar
8th Gear
i called the dealer (honda and acura) and they could not cross ref. the pillers. i called both america and they told me to check with a near by car club. so if the tl and the tls are the same, it will be the same as the honda? thanks.
Old Jun 23, 2003 | 08:04 PM
scalbert's Avatar
I seriously doubt the Accord and TL/CL are the same. The CL and TL share the same dash, etc. But I could be wrong but someone else would need to verify it though.
Old Jun 23, 2003 | 09:17 PM
kman156's Avatar
Exclamation TRUE!
TL/CL maybe diff because of the coupe design? but TL & ACCORD ARE TWINS! same sedan platform.
Old Jun 24, 2003 | 07:18 AM
scalbert's Avatar
Re: TRUE!
I made a special trip to the Acura dealer with a Mititoyo Hand Micrometer and the CL and TL are the same with the exception of the '02 TL having a cloth surface. The TL and CL are closer than the Accord is to the TL.
The Accord may share the basic chassis but that it completely irrelevant for trim. Also, I beleive there is a different rake on the windshield, a less thick A-Pillar along with a different dash which would certainly remove any possibility.
They all share the same lower chassis but the sheet metal varies along with interior appointments which is what seperates them all. But the CL and TL share the same dash, front roof line and windshield rake which allow it to share the same interior trim pieces. The Nissan Altima and Murano share the same lower chassis and both are four doors, they certainly are not twins.
Old Jun 24, 2003 | 05:18 PM
Paulie's Avatar
8th Gear
i looked at auto meter and they do not have a a pillar to fit... any suggestions... i don't care about the plastic and cloth because i can always put cloth over the plastic.
Old Jun 24, 2003 | 05:39 PM
kman156's Avatar
Re: Re: TRUE!
the gauge pods are designed to go over the existing pillar, so if the accord one is less thick, it can be fitted! my mother in-law has an accord ,and though i didn't measure it looked the same!? whatever, my pillar will be here by thursday, and i'll let you know what the dilly-o is! we shall know all very soon grasshopper!
Old Jun 24, 2003 | 08:32 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
I am interested
Old Jun 24, 2003 | 08:45 PM
scalbert's Avatar
Re: Re: Re: TRUE!
That is not the whole situation. The one Lotek will make does not go over the existing a-pillar trim piece; it replaces it.
The width is just a minimal part of it, there is also the form, the top and bottom angles to match the dash and headliner, etc.
Old Jul 8, 2003 | 12:51 PM
scalbert's Avatar
Here are the details:
Unpainted Price: $39.99
Painted (Ebony or Parchment): $47.98
US Shipping: +$5.99
Canadian Shipping: +$10.99 (Plus about Three Weeks Delivery)
Twenty pre-orders are required to begin manufacturing the trim piece. Once twenty orders are received they will begin the production of the mold and expect a shipping date of about eight to ten weeks after this point.
To place your pre-order please contact Lotek Directly, by email, phone or mail. Also, email me so I can keep track of the numbers to keep all parties informed of the count: scalbert@flwse.com
Here is the list I have so far. I know I missed a few but I do still feel we are short:
Username - Forum
scalbert - CL
Smitty - CL
CT3.2 - CL
ModAddict - CL
allmotor_2000 - CL
lou - CL
duy - CL
MtBikR - CL
schoeny14 - CL
mantis23 - CL
maevonee - CL
Juker008 - CL
ST2000 - CL
TLlikeWHOA - TL
TopGum - TL
badazzTL - TL
2001TL4KCdude – TL
Old Jul 9, 2003 | 02:57 PM
VTECRRR's Avatar
Exclamation kman the vtecrrr is in!
the honda pillar is gonna be a long time before it's done, and will need modification to fit. any of you guys putting in nitrous, which needs a pressurized hose to display your bottle psi, or boost, and or want to monitor tranny temp, oil, voltage, whatever you want to gauge? you'll need this mod! sweet that it's a-pillar, and not drilling into the dashboard! thanks scalbert for getting this off the ground!
Old Jul 9, 2003 | 06:32 PM
scalbert's Avatar
Here are the ordering details:
NO SALES IN THIS FORUM
Old Jul 10, 2003 | 12:19 PM
scalbert's Avatar
Thanks once more to the mods for reopening this and to VTECRRR's persistance.
Again, here is the information for those interested. Place you order with Lotek by either mailing a check, calling or faxing your credit card information to them. Specify that this is for the Acura CL/TL and also inform them of the color choice, Ebony or Parchment. The price is as follows which is for the dual pod trim piece or the two color choices shipped:
US $53.97
CA $58.97
Lotek, Inc.
715 - C2 East Geer Street
Durham, NC 27701
(919) 687-2762 Phone
(919) 680-6161 Fax
http://www.gaugepods.com
Old Jul 10, 2003 | 05:13 PM
songoku's Avatar
BlingBling INSPIRE 32V
What size gauge will be fit on there? 60mm??
Old Jul 10, 2003 | 06:27 PM
VTECRRR's Avatar
Exclamation 2 1/16th "
2' will fit too!
Old Jul 11, 2003 | 08:15 AM
scalbert's Avatar
Yep, 2-1/16 inch (52mm) gauges will fit the cut outs.
Old Jul 14, 2003 | 02:29 PM
kman156's Avatar
ORDERS ARE COMING IN!
just spoke with lotek and ordered my parchment gauge pillar pod! let's get it finished! some of you may have sent checks, but you can also call them and use any credit card! they still need some more $/orders to get the project build started, the sooner we order, the sooner we get our PODS! what good is a gauge without it's pod? so please those of you who want it, let's goooooo! lotek ph# in NC is 919-687-2762 thanks, steve k
Old Jul 14, 2003 | 02:35 PM
kman156's Avatar
Exclamation my gauges need their pod!!!
please give to the orphaned gauge society, and order your pod today! gauges need a home too!!! thank you!
Old Jul 14, 2003 | 02:47 PM
scalbert's Avatar
Re: my gauges need their pod!!!
As of right now I have only about five confirmations.
Old Jul 22, 2003 | 11:55 AM
scalbert's Avatar
Not good news so far. We have six (6) confirmed so far which is far short of the required twenty. I'll will give this until Friday until I call it quits; there is no reason to let this thing hang out there for too long.
The only other option would be to pay more...
Old Jul 22, 2003 | 12:30 PM
TopGum's Avatar
They got my check. C'mon people let's go!! This is awesome!
Old Jul 22, 2003 | 02:04 PM
VTECRRR's Avatar
17 names on the list
and only 6 orders? WTF? all you lame ass mother fvckers who have your name up there and haven't ordered! i'm gonna find each and everyone of you , hunt you down and kill you!!! j/k SERIOUSLY! get your ass in gear, and stop gumming up the works! $ 58.97 all of you can afford!
Old Jul 26, 2003 | 10:13 PM
TopGum's Avatar
So is this a dead issue?
Old Jul 26, 2003 | 10:17 PM
scalbert's Avatar
Not yet, I decided I would leave my stock trim piece at Lotek and just pick up the replacement piece at the dealer; it was only $26 anyway.
So it is still in the process and will continue until we hit the needed twenty mark. Whether that comes by way of twenty people or people buying multiple units (which has been discussed by myself and others) is unsure.
Old Jul 27, 2003 | 01:57 AM
kman156's Avatar
Thumbs down this is pathetic!
i cannot believe that those of you on the list, which when scalbert put you down based on your enormous interest!, and to which you basically made a verbal commitment! have now TOTALLY FLAKED??? the proposal was floated, and everyone who was all excited for such a great mod, jumped on the list, and then 70% of you just disappeared??? not very fair, or acting in good faith! just wanted to vent my disappointment in my fellow tl/clr's who have evidently bailed out of this project!
Old Jul 27, 2003 | 01:55 PM
ModAddict's Avatar
I called them to give them a credit card and was told "we are not set up for sales like that,... we will have to charge your card right away,...send a check and we'll hold it." I figured I would just buy it when it was available. I will be happy to send a check in ahead of time, but it looks like we're not even close. I will try to send it tomorrow.
Old Jul 27, 2003 | 04:08 PM
scalbert's Avatar
Lyle has been out of town so it seems some of the staff hasn't been too understanding of how or what should be done. I faxed them an order with my credit card information which seemed to be acceptable. Just FYI...
Old Jul 28, 2003 | 12:01 AM
TopGum's Avatar
Looks like most of those on the list are CL'ers. Who has not followed through ?
Old Aug 6, 2003 | 05:58 PM
TopGum's Avatar
I'm surprised more TL peeps arn't going for this. Even if you do not see a need now, maybe in the future? It sounds like a ONE TIME ONLY CHANCE. So, if you're on the fence, better go for it.
the update:
http://www.acura-cl.com/forums/showt...17#post1303917
