PCV Valve
Old Sep 6, 2008 | 09:52 AM
Papa_Sean's Avatar
PCV Valve
Sorry guys I know this is posted here already but the search function is not helping me out one bit. I've been putting this off for too long and now my car is idling strangely. It keeps dropping either when I slow down or come to a complete stop. Im going to attempt to clean the IAC and replace the PCV valve but I cant find the DIY. Any help is appreciated...
Old Sep 6, 2008 | 03:28 PM
ChrisQ1980's Avatar
hates the winter
The PCV valve is on the valve cover facing the firewall. It's on the driver side of the car. Easy to get to. I cleaned mine out with Seafoam Deep Creep.
Old Sep 6, 2008 | 08:59 PM
Papa_Sean's Avatar
^thanks I think I found it now...
Old Sep 6, 2008 | 09:08 PM
6MTUA5's Avatar
No He Can't
Pic?
Old Sep 7, 2008 | 01:24 AM
thescoundrel's Avatar
When I replace my PCV, I just used a pair of long-nose pliers and wiggled the valve out, don't go to hard and try to pull it straight out because you might damage the gromet, which could fall into the manifold which could be a big problem. If you replace your PCV, just put a little oil to help it slide in.
If you have plan to take out out your throttle body to get to the IAC, just remember to have a throttle body gasket handy if you damage the old one and label the hoses so you remember where they go.
The final thing to do is to remove the 7.5A #13 fuse on the passenger side to reset to ECU.
Good-luck. 200miles after IAC and PCV replacement no problems.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
