Passenger headlight low beam problems
I'm having problems with the headlights low beam. I changed both lights on both sides and checked and changed the fuse but the low beam on the passenger side wont turn on. All the other lights work except that one. Can anyone help with this or have any advice for me?
Welcome Princeofgantz65 !!!
The original "HID" low beam set-up on our TL's has an ignitor and ballast which may be causing your problem. Check the connections and grounds. Also look for any signs of moisture or corrosion.....as this will adversely affect the components and possibly failure.
If all else fails, consider replacing the old set-up with the newer "HID" aftermarket kits which are available for less than $100. For more info, try researching other pertinent threads and the "DIY" sticky for tips.
tman570
Jun 11, 2019 07:56 AM
marcelft
Jul 10, 2018 06:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
