Passenger fuse panel circuit tap question
Old Jan 14, 2015 | 08:30 PM
BetterBob's Avatar
Hey guys,
I have an FM transmitter that i have hard wired in to the car now, with the power going to the passenger side fuse panel.
Everything works, however the power to the transmitter dies when either door opens. I don't recall what circuit i tapped.
Anyone know what circuit I can tap that will stay on as long as the key is in the ACC or Run position? Only losing power when the key is switched off.
I could go out with my meter and test, but it's dark, and i figured someone here would know.
Thanks!
Old Sep 25, 2016 | 08:59 PM
WaarrEagle's Avatar
9th Gear
In case anyone stumbles across this like me, I had the same issue and finally found the P/W (power window) fuses are all switched. Nothing else in the passenger side fuse box seems to be (radio, nav, sunroof, cig lighter) but try the P/W fuses. There are 4... 1 for each window.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
datadr
Sep 12, 2015 09:12 PM
04tler
Sep 10, 2015 01:13 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
