Passenger front door.
Old 02-10-2019, 08:12 PM
Chiller2002TL's Avatar
I've been having this issue with my passenger front door for a while but because it closes properly with force not slamming I just rolled with it. But now it's starting to annoying me.
When I open it with the door handle I have to pull on it from outside / push it while inside and it feels very stiff like seized hinges but there's grease on them... When I close it normal it catches but don't close... I have to push on it or close it firmly
Is this an adjustment issue or do I need new hinges?
Old 02-11-2019, 11:41 AM
whitetiger5's Avatar
Have you lubricated the latching assembly in the door?
Old 02-11-2019, 01:53 PM
USAF Veteran
Saudade's Avatar
Check your latch adjustment. Also, does the door drop a bit when opening? Does it rise a bit when closing? Perhaps the door pins in the hinges are getting loose.
Old 02-15-2019, 10:02 AM
Passenger Door.
I don't know how to do a latch adjust on the doors. I've on'y done it to my civic hood... And no it doesn't rise or drop when opening/cosing . it's just stiff and heavy feeling. When you close it you don't get that silent thump .. Its like metallic like shutting it on your seatbelt buckle..
As for grease the hinges I use some white lithium grease but not sure if it's enough and the can is done...
That middle arm piece that stretches between the door and the body should that be greased and with what?
Thanks.
Old 02-18-2019, 04:57 PM
The service manual states to use multipurpose grease on door hinges.
DeathMetal
01-17-2019 12:53 AM
broly
07-25-2017 03:15 PM
NC916
10-18-2012 05:27 PM
mokTL
07-28-2009 09:01 PM
Rice1304
02-25-2001 09:27 PM
Quick Reply: Passenger front door.
