painting engine cover question
Old Apr 22, 2008 | 03:30 PM
lopez819's Avatar
Question painting engine cover question
can i use duplicolor chrome paint on the engine cover? i was at autozone and the guy there told me that it wouldnt work because i need high temp paint. i searched and read some members on here say that any paint will work. i just dont wanna spray the engine cover and the paint melts and messes up the engine.
as far as the painting goes, should i just sand, prime, and paint?
heres a link to the chrome paint:
http://www.duplicolor.com/products/gold-chrome.html
Old Apr 22, 2008 | 03:33 PM
jjashaa's Avatar
Avant Garde Wheels
and clear.
i used just regular duplicolor paint and it is still holding up great.
wouldn't melt. shouldn't. and won't ruin your engine..
Sand down to smooth. primer... wet sand... primer.. base coat.. blah blah... and clear..
Old Apr 22, 2008 | 03:40 PM
fsttyms1's Avatar
You DO NOT need high temp paint. If it got that hot in there the body panels that are painted would have melted paint, plastics would melt etc.... Any paint will work.
Oh and spray that paint on something else first to make sure you like it. I havent seen a instance where that paint looked good yet.
Oh and clean the cover up really well with dawn, scuff it up with a scuff pad, and primer it with a high build primer. It will turn out smoother and better looking
Old Apr 22, 2008 | 06:54 PM
fiznerch25's Avatar
99 TL p
i used the duplicolor metalic blue, or something like that . just prime several coats, followed by several color coats, followed by several clear. light sanding before each coat worked out great
drone619
Jan 26, 2016 07:09 PM
sockr1
Oct 1, 2015 01:31 AM
eastcoastguy
Sep 24, 2015 02:07 PM
wusty23jd
Sep 24, 2015 11:41 AM
JnC
Sep 11, 2015 06:06 AM
