P1399 Help
P1399 Help
Did a search and can't find... P1399 CEL code, it came along with P0300, P0301, 02, 03, 04, 05, 06, which I know are misfire codes but the P1399 isn't listed. Maybe someone can help?
Thanks, Jeff
Thanks, Jeff
Originally Posted by rustee
HI mezzerTL-S did u ever figure out what the codes were? i have the same codes and i dont know what to do, any feedback will be apreciated.
thank you
thank you
thank you
thank you
thank you
thank you
You really dont. Buy 1 new coil. Find a cyl to start on. Replace the coilpack on that one with the new one. clear the ECU and run the car to see if the code comes back. If so take that coil off and replace with the one you took off and move on to the next. This procedure has worked for many. (while it is possible you have more than 1 bad with the multiple like that its most likely you just have 1)
Originally Posted by T4Texas
Where is a good place to buy a new coil? I'm getting the problem on my TL, multiple misfires.
knice
Jul 15, 2015 01:40 PM
typeR
Jan 2, 2007 08:39 AM
