outside temp reading
Old Jan 22, 2011 | 08:15 PM
jlbrannen's Avatar
New Problem! finally changed the cabin filters. i've owned this 99 for 4-5 years, and the originals were still in there. pretty gross. took all of 30 mins to do it. don't know if there is a connection, but now the outside temp reading on the dash instrument is way off. i'm in san diego, and it's in the low 60's tonight, and it was saying it 86 outside, now the auto climate isn't working cuz it thinks it hot outside. anyone know whats going on here?
Old Jan 22, 2011 | 10:08 PM
fsttyms1's Avatar
Not related. The sensor is in front of the radiator. Did you try resetting the "maintenance required" light? Had the car been sitting hot for a while when you first noticed it?
Old Jan 23, 2011 | 11:05 AM
01tl4tl's Avatar
there are 2 interior temp sensors- one has been blocked or disturbed somehow?
look on top of dash and by your right knee for them
those run the auto climate
the outside temp `display adjustment` range is 5 degree + -
its purpose it to advise of freezing temps that can produce road ice
as said- its sensor is in front of the radiator where it gets hot when parked,
and after 5 minutes driving should be correct again
You use the trip buttons and key position to get to its adjust mode-
can be accidentally done while trying to reset oil minder/mait light
Old Jan 23, 2011 | 11:06 AM
01tl4tl's Avatar
if you turned up the auto climate to high 70s and got no heat- look at threads on blower motor door
Old Jan 24, 2011 | 11:33 AM
jlbrannen's Avatar
i did replace the windshield along with the mirror, maybe the installers messed up the sensor on the dash. today it seems to be working better. i'll keep an eye on it and report back
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
