Outside temp gauge
Old May 27, 2010 | 12:01 PM
Bham03TLs's Avatar
Outside temp gauge
My outside temperature gauge is off by a like 6 degrees and i was wondering if anyone knows how to change it to the correct temperature? I think i did something to it when i was resetting the check engine light after an oil change, but i couldnt figure out what i did. thanks
Old May 27, 2010 | 12:06 PM
hANDYcaptd's Avatar
It's the Halladay season!
Is it consistently off by that much? It will read high when it's been in the sun for a while.
Let it cool in the shade and see if it's still off.
Old May 27, 2010 | 12:25 PM
my.daily'tl''s Avatar
Always Working In
Those same two buttons do control the temp reading also. I remember it was almost the same as resetting the CEL. I remember one you have the ignition on when you press the two and the other you don't. Its tricky setting it. It jumps at 3 degree intervals.
Old May 27, 2010 | 03:45 PM
01tl4tl's Avatar
my 01 has a 5 degree up and down range iirc in 1 increments
The intent of temp guage is so you know when ice on the road is likely- within 5f of 32
and to remind you its 110 outside and the ac is working hard to keep 68 for you
to set perfectly- look in front of radiator for a metal probe in a clip
pull it from the clip and place in container of water and ice- mixed
so its approx 32f in the container
turn key ON- dash lights ON but not car start
press both trip buttons- it goes into adjust mode, set as needed
or - a known good temp in shade reading from other guage or sign- after you have been moving for 10 minutes or more so the temp is stable where the sensor is
When the car sits after running it gets hot there
So when view a known reading -- set car to match
for oil minder reset-starts flashing after ~6500miles since reset
its left hand thru steering wheel to push and hold both buttons- then turn key to on, wait for `mait req` light to flash several times then stop
turn key off and remove arms
Old May 27, 2010 | 03:48 PM
01tl4tl's Avatar
to reset the ECU to clear a CEL-
remove, wait a minute and reinsert the clock fuse from passenger side end dash fuses-
thats the secret backup power for ecu and forces a master reboot and self test
Old May 27, 2010 | 04:35 PM
Always Working In
Ooops did I say CEL? I meant the reminder light!
Old May 27, 2010 | 06:51 PM
CAB NY's Avatar
Tri State ViP Crew
mine is about 5 degrees higher too I'll try that reset method
Old May 27, 2010 | 10:30 PM
friesm2000's Avatar
B A N N E D
an 03 only have like a total range of 6 degrees though plus 3 and minus 3
and btw the correct way to set it (per service manual), is to put the sensor in a cup of ice water, then set it off of that
Old May 27, 2010 | 10:40 PM
01tl4tl's Avatar
thats right- and not everyone is willing to do that-
so the alternative is go off the local electronic signs..and set to them
for summer use its close enough
for winter- exact calibration can be a lifesaver
Old May 27, 2010 | 10:46 PM
friesm2000's Avatar
B A N N E D
exact calibration, but even if it reads like 36 degrees, you should be expecting to possible be seeing ice though, especially depending on if the road is shady or not though
Old May 27, 2010 | 10:48 PM
friesm2000's Avatar
B A N N E D
and iirc, those mirrors that read outside temp, alot of them will say ice or something along those lines once it does hit like 36 degrees or something
Old May 28, 2010 | 03:19 AM
01tl4tl's Avatar
wow I dont have that mirror feature
I have to use my brain and know that 5 degrees F either side of 32 and you can expect ice on the road if moisture has been present
On bridges or overpass where the road gets extra chill from below, be extra careful as they are more likely to have black ice- hidden death, and hold ice at higher ambient temp- the road temp is cold
Areas in shadow are even worse, dont get dried out surface and layers can build up with slush in between
Seems odd to talk about this in may ,,but once again its snowing in Lake Tahoe Ca for memorial day weekend- they even opened 2 ski resorts at the top of the mountain--that had closed a few weeks ago thinking snow season was finished
Old May 28, 2010 | 08:06 AM
friesm2000's Avatar
B A N N E D
mirror feature, i mean like other cars for it, but yeah still always helpful though
but yeah all you really need to know is if it anywhere near freezing and to slow your ass down and possibly expect ice, cause the temp sensor only reads the air temp outside and not what the actual surface temps are
and about may, we had snow at like the beginning of may here, so no worries about that lol (and the mountains are still getting the occasional snow also), but now we got hail instead :S, i still would prefer snow though, especially considering some of the size of the hail we have been getting
Old May 28, 2010 | 08:11 AM
friesm2000's Avatar
B A N N E D
btw try this and sorry it only provides that ice warning for like a minute then goes back to reading the temp
http://www.mitocorp.com/auto-dimming...s.html#Outside
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Jboat
Sep 30, 2015 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
