Outside Temp Gauge
Old 08-05-2002 | 06:02 PM
Manus99's Avatar
Outside Temp Gauge
The outside temp. gauge on my car has a problem, the highest it will read is 84 degrees. I know this is way off because I live in NJ where the temperature is above the 90s. Also my parent's TL measures 98 and other high temperatures while this one goes to only 84. Anyone ever had this problem or know how to fix it? Thanks.
Old 08-05-2002 | 06:11 PM
drcookie's Avatar
I have a 2002 TL-S and so far the gauge has gone as high as 99, have not seen it breaks 100 yet.
Old 08-05-2002 | 06:25 PM
You can adjust temp to reflect the real one. After adjustment mine is Very accurate after I drive few miles.
Check your manual
Old 08-06-2002 | 01:39 PM
eddiemac's Avatar
Mine has been as high as 105
Old 08-06-2002 | 01:57 PM
juniorbean's Avatar
Lightbulb
This could be the highest reading I've seen:
Taken from:
http://www.acura-cl.com/forums/showt...threadid=76789
As Beiruty said... you can adjust the guage if it is that far off. Check in the manual as it tells you how to do the adjustment.
FYI.....mine is usually pretty accurate as well.
CL-S progression 01
01-26-2016 04:15 PM
Jboat
09-30-2015 10:58 AM
Ratheruneeq
09-28-2015 07:41 AM
Quick Reply: Outside Temp Gauge
