Outdoor temperature gauge
WayTooManyAcuras
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
YIKES!
:-jon
:-jon
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Last summer the gauge on my TL was always up at around 117 when I would get in the car after work. This was when it was around 100 outside. In fact, it has always read a little high. Of course, if you take into account the heat index (heat + humidity), it is probably just right.
Of course, maybe Acura IS measuring the heat index, but I doubt it.
Thermometers shouldn't take into account the humidity. They only measure air temperature, but higher humidity makes the human body feel a lot warmer.
Just to be picky...![](http://www.acura-tl.com/ubb/smile.gif)
2002 Acura TL-S w/ Navi
Aegean Blue
Underbody kit
Spoiler
Former: 1997 Acura Integra GS-R
Pioneer Head Unit, CD-Changer, EQ, Boston Acoustics separates, 2 - JL 12W4s, Kicker & Pioneer Amps
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by MCD on April 19, 2001 @ ]</font>
Just to be picky...
Aegean Blue
Underbody kit
Spoiler
95 Integra GS-R Stock
2002 TL-S Aegean blue
Sticky Rice OwnZ joO
1 Post
Hi guys,
FYI
the temperature gauge is not accurate unless you are going 35mph or faster. At least that was the case for 99-01, but I doubt they fixed that on the 02.
If you want more info, do a search on the subject, it has been covered quite extensively.
Glad that it is warmer down in So Cal, I'm going there this weekend. Sick of this gloomy rainy days in the bay area.
FYI
You know what they need? A temperature of the inside cabin. I know they have to check it for the auto climate control, but you know what the goal is, not what it really is. I'd be interested to know because I'm in Phoenix, AZ and the temperature inside is way hotter than the outside during the summer...115 outside means 130 or so in side....I can't wait until summer
![](http://www.acura-tl.com/ubb/wink.gif)
Originally posted by Raptor:
I read in the manual that the thermemeter is located under the front wheel bumper. Unless you are traveling at least 35 miles per hour it will not give an accurate reading. Look it up.
1 Post
Originally posted by litTLeton:
Try this if you want the inside temperature. Set the a/c for 65 and auto and
the blower fan should come on very high.Start turning the temp up until the fan stops.That will be the inside temp.John
![](http://www.acura-tl.com/ubb/biggrin.gif)
Dr. TLS
Originally posted by californiacat28:
Does anyone know where the Outdoor temperature gauge is physically located?
the actual device that reads the temp is located near the hood latch supposedly, though ive never actually seen it
you can recalibrate the guage if you feel its off in any way by pushing a combo of the reset/select trip meter buttons
if you still feel its off, youll have to remove the meter in front of the car and put it in a ice cold glass, then recaliblrate it though the trip meter buttons
Follow as i ride
99 Satin Silver
Bridgestone RE-730 225/55/16
oem kit
ctech exhaust
ctech sways
aem intake
system
Follow as i ride
99 Satin Silver
oem kit
ctech exhaust
ctech sways
aem intake
system
Yes, it definitely has 3 digits. I have seen over 110 here in Dallas many times. ![](http://www.acura-tl.com/ubb/frown.gif)
It also seems a little high at times - perhaps it is not calibrated correctly to compensate for under-hood ambient temperatures. It seems to be the highest when parked for a while, and I assume that it is the engine heat.
'01 White Diamond Pearl 3.2TL
-Wing, tint, wood and Whistler
I have noticed my temp guage reads 2-4degrees high and it is slow to equilibrate onece you drive it. On my 2town cars and 2 caddies I've owned, once you started driving it only took a mile or 2 before they were right on the money. I think the temp sensor is located in a bad location. I have had lots of digital thermometer( indoor/outdoor etc and played with them placing them in freezers etc. and it only takes a few minutes for them to equilibrate.
