our cars are DOHC?
our cars are DOHC?
a freind that once worked in the parts department, is now in sales and told me that pretty much all the brochures have a typo somewhere. he said that he looked up on the parts catalogue for the tl, and he saw a cam for the intake and for the exhaust. i doubted him when he told me the tl has dual overhead cams, but he was positive.
this isnt just a kid with a lowered teg, he knows his stuff
anyone know this?
Follow as i ride
99 Satin Silver
Bridgestone RE-730 225/55/16
oem kit
ctech exhaust
ctech sways
aem intake
system
anyone know this?
Follow as i ride
99 Satin Silver
oem kit
ctech exhaust
ctech sways
aem intake
system
Single Overhead Cam for us.....(SOHC)
As quoted from Acura.com:
3.2-Liter SOHC 24-Valve V-6 VTEC™ Engine
An advanced, all-aluminum, 3.2-liter 24-valve 60-degree V-6 engine powers both the 2002 3.2 TL and TL Type S. These engines are compact, lightweight, and incorporate advanced technologies like Variable Valve Timing and Lift Electronic Control (VTEC™). The Type S engine boosts output through the use of a unique dual-stage induction system, high-flow exhaust system, exclusive camshaft design and a higher compression ratio.
Ed
Acura-TL.com - Forum Moderator
'66 Mustang Fastback
'99 Mazda Miata
'99 Acura TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
'99 Mazda Miata
Pics of my TL
We do have 2 cam gears persay. But the TL is not a DOHC. There is one cam for each of the 2 banks of 3 cylinders. So technically we are SOHC. If we had a DOHC engine then we would technically have 4 cam gears.
Y2K SaTiN SiLvEr 3.2TL
-AEM Short Ram intake w/heat shield
-AEM Tru-power pulleys
-Magnaflow exhaust
-Ground Control coil overs
-BLITZ 1.3 kg radiator cap
-BOSCH platinum+4 plugs
-Factory underbody kit and Wing
-Mesh grill
-Body color door handles
-20%/35% Llumar Platinum tint
-Räzo Shifter
-2 Rockford 10" XLC subs/Boss Audio CLR60 amp
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
would there be any benifit if we did have sohc or dohc?!
for the ppl who dont know what sohc mean it is a rod that goes across horizontally in the engine with that hit valves to open up exhaust and then intake repititiously(blah)dohc would be one with a double rod going across
im figurin dohc would be a better breathing engine wouldnt it?!
Guest
Posts: n/a
DOHC VTEC operates intake and exhaust, SOHC VTEC operates just the intake side.
If the TL was DOHC, it would require a taller engine bay (higher hood), which is kind of a no-no for aerodynamics.
Had 2000 3.2TL... Realized I like smaller cars.
Now I have:
2001 Civic EX Coupe, Black, Auto... wife uses mostly. Getting 36 MPG overall.
Pictures
1999 CR-V EX 4WD Auto White... bad weather car, hauls stuff including bicycle.
1992 MR-2 5-Speed T-Tops 2.2L, Greddy SP S/S Exhaust... sunny-day car.
Next up: MR2 gets sacrificed to make garage
space for a Yellow S2000!!!!
Now I have:
Pictures
Guest
Posts: n/a
SOHC VTEC uses 5 cam lobes per cylinder, all cut on the same camshaft. 3 open the intake valves, 2 at low RPM duty and 1 wider one at high RPM. The other 2 cam lobes open the exhaust valves.
DOHC VTEC uses 6 cam lobes per cylinder, 3 on the intake camshaft, 3 on the exhaust camshaft. It's the "additional camshaft space" of a DOHC arrangement that makes a more aggressive VTEC possible.
Now I have:
Pictures
Now I have:
Pictures
