one touch sunroof
Old 06-17-2005 | 02:30 PM
Afro TL's Avatar
crazylokko
Question one touch sunroof
Okay I own a 99 TL and I am wondering if it is possible to upgrade the sunroof motor button so that it opens with just a touch without holding it down.
anyone tried this or have any suggestions?
thanks
Old 06-17-2005 | 02:49 PM
TLofNYC's Avatar
Registered Abuser
yeah that sucks that we have to hold the button to open the roof. My last car, 99 toyota solara, had one touch and the AC doesn't.....
Old 06-17-2005 | 03:23 PM
Afro TL's Avatar
crazylokko
yes it does I wonder if it is possible to do one touch like the power windows
Old 06-17-2005 | 04:14 PM
MegaKillTron's Avatar
The wood god
yeah that would be pretty cool
Old 06-17-2005 | 05:03 PM
Shaqs2002TLS's Avatar
Do a search on the site, someone has already did this.
Old 06-17-2005 | 05:25 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
I did it
im gonna try to find that DIY i did a while ago... hit me up with a PM just to remind me.
Old 06-17-2005 | 05:29 PM
https://acurazine.com/forums/showthr...relay+moonroof
Old 06-17-2005 | 06:49 PM
Afro TL's Avatar
crazylokko
Originally Posted by Shaqs2002TLS
thanks I will take a read at it
Old 06-17-2005 | 07:21 PM
Afro TL's Avatar
crazylokko
Originally Posted by @cUr@-TL
I did it
pm sent
too bad you are not in Calgary I will pay you to do it.
Old 06-17-2005 | 07:53 PM
Afro TL's Avatar
crazylokko
okay update I talked to my audio installer and he says he can do it for me I already have an appointment with him to install my after market fog light sometime next weekend, so I will keep you guys up to date on how it all works out....
Old 06-17-2005 | 10:16 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Either u can use 1 DEI 528T and some relays or just use 2 DEI 528T's. They are about 20 bux a piece. This can be done with a bit of wiring. However make sure to get a good ground or else these pulse timers will cut off too short.
Old 06-17-2005 | 10:44 PM
TeknoKing's Avatar
here is where the trick comes on, yes the above mentioned works, but in most cases if you leave your moonroof on a tilt, it might give you a problem when closing the roof thru 528T
Old 06-18-2005 | 01:22 AM
Afro TL's Avatar
crazylokko
could you explain further please...what kind of problem does it give when closing?
Old 06-18-2005 | 01:38 AM
D. Jeckle's Avatar
Mazda=redneckricer
WOW! the man actually says something that makes sense.
Try a 530T it should work better
Old 06-18-2005 | 02:11 AM
Afro TL's Avatar
crazylokko
what is the diff b/n a 528 and 530
Old 06-21-2005 | 10:49 AM
arcangel79mc's Avatar
Smile.....you drive a TL!
I have got to know what that clip is form its hillarious!!!
Old 06-21-2005 | 11:06 AM
Bxscig's Avatar
eh no DEI530T or DEI529T will NOT work, that is why most installers cant figure it out and end up putting it into the tilt mode and eventually gives up.
Only the 528T will work, ONLY because it is a timed relay. The DEI530Ts and DEI529Ts are not timed relays, the are window modules and sense if the motor has resistance.... IE closed or all the way opened.
I have not had any problems with the DEI528Ts, well if I had completed installed it then there would be no problems. Slightly little thing that I have to wire correctly.
Old 06-21-2005 | 11:08 AM
Bxscig's Avatar
Definitely wont work
Exactly
Old 06-21-2005 | 04:15 PM
***EL*MAFIOSO***'s Avatar
blACk AC in sAC
...okay, so who's gonna hook mine up? and how many beers do ya want for it?
Old 07-31-2005 | 03:34 AM
Afro TL's Avatar
crazylokko
Yeah!!!!!!!!!!!!!!!finally I got my one touch sunroof setup...it is nice to have it....
Old 07-31-2005 | 06:17 AM
MikePA's Avatar
That thread has the parts, but the wiring diagram is missing. Can anyone supply that?
Old 07-31-2005 | 08:52 AM
Bxscig's Avatar
Good job, which way did you wire it? 1 or 2 528ts? or did you use another method?
Old 07-31-2005 | 01:55 PM
Afro TL's Avatar
crazylokko
I can say for sure that it was 2 but I did not install it myself...knowing me I would have fried my car...lol I got the guy who installs my audio to do it for me and I only paid for the parts...$50.00
mlody
12-04-2019 02:11 PM
TL14
09-24-2015 04:37 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: one touch sunroof
