oil leak dont know what to do?
99 tl 100 k leaking engine oil dont know were its coming from i think its coming from between the motor and tranmission
majority of the time its your valve cover gaskets. Look at the rear one and see if its the case if not, check your oil filter and drain plug to make sure its tight and secure.
Hopefully its not the head gaskets. that would be a fun project.
good luck!!
good luck!!
Originally Posted by figueroa1357
went to the mechanic he said its the rear main seal he said he would do it four hundred bux and it will take two days
Gaskets and Seals
I am sorry to ask the question, but where is the Head Gasket and Rear Main Seal located? I have heard these terms before and they appear to be a real time consuming jobs, but not sure what gasket or seal they are.
Thanks much.
Thanks much.
IBankMouse
06-13-2020 12:53 PM
