Oil leak around engine?
If I had to guess, it's possible that the leak, in the picture above, is the front head valve cover gasket. #4 on the link below.
https://www.acuraoemparts.com/v-2003...der-head-cover
There could also be a secondary leak from the O-ring (#15 on the link below) located on the front head camshaft thrust cover assembly #6 on the same link.
https://www.acuraoemparts.com/v-2003...-cylinder-head
Best guess is that the leak above may be associated with the O-ring (#17) on the inlet joint (#27) on the link below.
I think the inlet joint is made of plastic, not sure; therefore, it's possible that it could be cracked as well. Just throwing that out there.
https://www.acuraoemparts.com/v-2003...s-pump-bracket
Or O-ring #23 on the link below.
https://www.acuraoemparts.com/v-2003...s-pipes-type-s
An easy way to try and determine the origin of leaks is to hose down the area(s) with brake clean to clean-up the grime. Then observe either with the car running or over a period of time to see if one can pinpoint said leak.
