Oil change
Old May 17, 2006 | 07:49 AM
91300zx's Avatar
Oil change
I am picking up my 2002 TL-P tonight and I am going to stop and buy some oil to change it myself. How many quarts does it take ? Is the oil filter easy to get to ? If it's a pain then I just have Jiffy Lube do it.
Old May 17, 2006 | 08:05 AM
fsttyms1's Avatar
The tl takes 4.6 quarts ( ive added the full 5 for 200k with out a problem as have others) the filter is very easy to get to. If you turn the wheel all the way to the right and look in hte passengers side wheel well you will see it.
Old May 17, 2006 | 08:34 AM
91300zx's Avatar
Some people in this forun use Mobil1, 0W20 and some use 0W30. I am thinking about getting 5W30 for year round.
What do you guys think ?
Thanks again
Old May 17, 2006 | 09:00 AM
acutee's Avatar
5w30 should be find. especially if your car has high mileage don't use 0w20
Old May 17, 2006 | 09:31 AM
xanctus's Avatar
Plus on the manual it says 5-30 oil and I usually get the filter from dealer. Or you can get aftermarket maybe...but I am just to bloody lazy to look around.
oh yes in the manual also shown how many quarts u need. I usually get the oil from Wallmart (mobil 1 5-30, the big bottle one which is 5 quarts I believe, cost around $21 or so).
Good luck
Old May 17, 2006 | 01:06 PM
phipark's Avatar
Not Asian
Originally Posted by 91300zx
Thanks again
Mobil 1 is good. Go with 5w30 or 5w20. You can get a 5 qt jug at Wal-Mart of 5w30 for around $22. I use the Mobil 1 oversized filter, M105. The M104 is the "regular" size. Also, get some new crush washers from the dealership.
Old May 17, 2006 | 01:28 PM
DzTL-S's Avatar
If you are going to do that mind as well change your transmission oil too
Old May 17, 2006 | 02:06 PM
tommiesay's Avatar
Acura TL 2000
i had my car over a year now...and it has about 88,000 miles on it...and i been using 10x40
can i change it to 5x30?
Old May 17, 2006 | 02:19 PM
acutee's Avatar
sure you can, shouldn't be a problem.
Old May 17, 2006 | 02:45 PM
phipark's Avatar
Not Asian
Old May 18, 2006 | 06:34 PM
Severin's Avatar
If you have a Sam's Club the a 6 qt box of Mobil 1 5W30 is $24.
As long as you thoroughly wipe the old washer and mating surface and don't over torque it you'll NEVER need to replace the stock metal washer (115K on mine).
Old May 19, 2006 | 04:07 AM
91300zx's Avatar
Where do you buy M105 Mobil oil filter ? and will this be ok to use on my 2002 TL-P ?
Old May 19, 2006 | 08:29 AM
fsttyms1's Avatar
LIke discussed by our resident oil expert, id stick with the M104 Oversized isnt always better
Old May 19, 2006 | 12:50 PM
acurabum's Avatar
I got a question : I heard that switch to Synthetic after 30k miles and more will
make your engine burn oil and make some noice when is idling ? If your millage is
over 30k miles some sugest to stick with conventional oil . What to bevieve ?
Old May 19, 2006 | 01:00 PM
fsttyms1's Avatar
Not true at all. I switched at 100k. You can even go back and forth between regular and syn or even mix. No need to fear. switch over
Old May 19, 2006 | 01:07 PM
acurabum's Avatar
Thanks Batman By the way , heard your car is alive ..
but any run yet?
Old May 19, 2006 | 01:48 PM
Tom Blasing's Avatar
is the Mighty Favog
nevermind
Old May 20, 2006 | 01:22 AM
SodaLuvr's Avatar
Only use the M1 EP-104 sized filter or Napa Gold 1334 filter. Larger is not necessairly better as different grades of media are used depending on the size, to meet the drain intervals specified by the OEM.
M1 5w-30 will work fine, and is cheaper and easier to obtain. There is no harm to using it in place of any 5w-20, but definitely wait until you're out of warranty.
Old May 20, 2006 | 02:53 AM
Severin's Avatar
At least in '00 and '01, the US manual spec'd 5W-30; somewhere thereafter that changed to 5W-20 if I remember my forum reading - what year was that and what was the reasoning (emissions/mileage) since the engine was unchanged year to year?
Old May 20, 2006 | 06:14 AM
91300zx's Avatar
Mine is an 02 and its manual says to use 5w20, From what I've heard, you can use 5w30 and it doesn't void the warranty. The reason they want you to use 5w20 because of emissions and gas mileage improvements, and yes you are correct.
Old May 20, 2006 | 12:10 PM
SodaLuvr's Avatar
Yes, you can use 5w30 without technically voiding your warranty, but why ask for greater hassles in the event of a warranty claim?
They went to 5w-20 due to the improved performance/wear control of the better 5w-20 oils while still allowing for fuel efficiency gains and more rapid cooling (due to better flow).
Old May 20, 2006 | 12:21 PM
ou sig's Avatar
Boomer SOONER
I thought the "better mileage" was from the first # - going from 10w30 to 5w30???
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
