Oh no, not another problem!!!
Old Jan 9, 2003 | 11:49 PM
I was driving home tonight when I noticed a high pitched squeaking noise coming from the front end of the car. When I turn my steering wheel left or right the noise appeared near the tires, possibly in the rack/pinion or other steering mechism. The steering fluid is full so that can't be the problem. Has anyone have a similar situation? Any idea what the deal is? Thanks...
Old Jan 10, 2003 | 08:11 AM
Tatewaki's Avatar
I'd say take it to the dealer. I hope it's not your CV joint. Check for leaks around the boot and inside the wheel well.
Tatewaki
Old Jan 10, 2003 | 08:58 AM
Turboara's Avatar
could be the belts too
Old Jan 10, 2003 | 04:48 PM
jdone's Avatar
Yep, power steering belt is slipping-cheap/easy to fix while you wait.
Old Jan 12, 2003 | 12:09 AM
russianDude's Avatar
Had the same problem on my 2001 CL, they lubricated ball-joint and the problem went away, now its back, and the dealer told me that this time they will replace entire ball joint....
It happened to few people, not to common .... but I've seen about 5-10 people complain on CL forum...
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
