OEM alt upgrade options?
Old Mar 14, 2013 | 02:57 PM
my240sx4u's Avatar
do we have any options, i know when i had my 240 we could use quest alt's. do the vans or pilots have alts that put out more amprage?
Old Mar 14, 2013 | 03:05 PM
fsttyms1's Avatar
The type-s is higher than the TL-P if i remember correctly.
Old Mar 14, 2013 | 03:47 PM
TLer trash's Avatar
I'm pretty sure the tl-p is 105 amp, the tl-s is 120, and the odyssey and/or pilot is 135 or 140.
Old Mar 14, 2013 | 04:39 PM
Skirmich's Avatar
TL-P is 110A and TL-S is 120A
You can use a Direct Bolt On Odyssey ALT for 130A
or get a Rewind for more Power..
My Question is how much power your planning on delivering?
TL-S Alt can in my Experience hold 1K RMS easily.. the Ody Alt somewhat 1.3K RMS.
Old Mar 14, 2013 | 05:50 PM
3.2TLc's Avatar
Mo power for the amps ?
Old Mar 14, 2013 | 09:16 PM
my240sx4u's Avatar
little bit more juice, not going crazy just in the planning stages and trying to get everything in line, looking at a 600w 4ch amp, and 2 1000w mono's all pushing 2 dd 10's, probably a 2f cap also, still planning tho things can deff change tho as i still have a few things to do before i get to this point, but the info is great to know when my alt goes out lol. thanks everybody
Old Mar 14, 2013 | 09:30 PM
Skirmich's Avatar
True 600w and 1000w? cuz thats crazzyyy Power..
2600W RMS will require a Full Hand Winded Alternator for Sure.
Old Mar 14, 2013 | 09:44 PM
my240sx4u's Avatar
thats what the plan is right now....but as my priorities change around on the car, and if my direction with how i see my car sitting in the next year changes then no, but otherwise yes.
I plan on doing almost a full dd setup, i really love how their products sound.
not only will i have to upgrade my alt setup but alot of other electrical components as well, so we shall see
Old Mar 14, 2013 | 09:52 PM
assclown's Avatar
2000 acura tl FPR
damn, I didn't know the base and type s had different alternators. I'm still on my base alternator, but I'm not running a stereo system or anything.
Old Mar 14, 2013 | 11:38 PM
Chevelle66's Avatar
Get a custom alt, will be better than a rewound stock. Will put out more power at lower rpm's and will last much longer. I got a quite from Tenney alts for $325 shipped for a 200 amp. A 180 amp was $275.
And ditch the capacitor, it 99% of people don't need them, and misuse them as a bandaid for insufficient electrical.
DD makes good subs, and they cost it too lol. But as far as components I'd look elsewhere. Myself and a few other I know are running the new JBL ms series and sound amazing. Im running them active off an 80prs.
Old Mar 15, 2013 | 12:35 AM
Skirmich's Avatar
With 2K RMS Im thinking more of a 200A Alternator and 2 Battery´s (Hood+Trunk) with 1/0AWG Power and 2/0 for Overkill...
And Im in the No Capacitor Crowd.. Capacitors are just a gimmick.
Old Mar 15, 2013 | 01:41 AM
the-G-ride's Avatar
I have a tl-s and I run a 1100w class d 5 channel amp, when I bump it, my interior lights start to dim. So you'll definitely need a custom alt with the setup you're going with. Werd on ditching the cap, its pointless if you ask me. I've used ohio genorators custom alts before, their a bit on the expensive side but its worth it. When I decide to go bigger, I'll try them or DC.
With all that power, you should look into orion subs.
Old Mar 15, 2013 | 02:58 AM
Skirmich's Avatar
Need to check your stuff bro... Im running 1K RMS with no light issues (Have SMD Interior Tough)..
Upgrade Battery? Hell alot of Things but the TL-S Alt is good for 1.1K RMS I would even dare to say 1.2K if your not running accesorys.
Old Mar 15, 2013 | 09:17 AM
03tLsNBP's Avatar
MechEng
I was running a Hifonics 2000W 4 channel and Hifonics 1500W mono amp, 4 6.5s, 2 tweeters, 2 3.5s, 2 6x9s, and 2 10" subs with no capacitor and stock Type S alternator. I didn't have any issues with lights dimming.
Old Mar 15, 2013 | 09:20 AM
victus1's Avatar
Here's a good analysis of capacitors:
http://fatfist.hubpages.com/hub/Car-...They-DONT-Work
Old Mar 15, 2013 | 05:03 PM
Skirmich's Avatar
Holy Crap! Thats Asking the God of Electronics to Destroy your Alternator It may work but your alternator will run SUPER HOT (Depending on Load = High Volume) possibly taking alot of the bearing life and Stator Brushes.
Also those Hi-Fonics are A/B which are pretty Un-efficient.
Old Mar 15, 2013 | 06:28 PM
03tLsNBP's Avatar
MechEng
inefficient***
yeah I had plans to do the Big 3 and upgrade the alternator but I never got around to it before I parted out. the setup is for sale now.
Old Mar 15, 2013 | 07:45 PM
my240sx4u's Avatar
good reading on the caps, might just ditch them. i also agree on DD mids, i like focal mids but im not sure if i want to spend that kinda of money on mids atm. i also loved my old BA components, so im not sure on what i will do for mids.
Slow98teg
30
Jan 2, 2017 09:01 AM
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 09:01 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
