OE or aftermarket rotors
Old 08-28-2007, 02:28 PM
  #41
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
sandpaper the rust off the rotor before painting
if any paint overspray:
sandpaper it off and shoot some brake cleaner to wash off the rest- no sweat
I cleaned my RacingBrake 1 piece slotted rotors with 120 grit wet/dry wrapped around a small block of wood, and wd40 as lube
Knocked the dark color from Hawk pads right off and left clean rotor surface for the new EP300 pads from racingbrake to make their transfer layer to
Have fun! paint the calipers and their brackets black for brembo fakes
  #42
01tl4tl's Avatar
And as long as you have the wheels off- bleed those brakes!!!!
Old 08-28-2007, 02:42 PM
  #43
dnd2984's Avatar
How long will the whole process take Tom? I have only couple hours to spare tonight.
Old 08-28-2007, 08:36 PM
  #44
dnd2984's Avatar
http://www.bendixbrakes.com/products...ionPremium.php
for the rears. I know these are good as OE so was thinking about using them on the rears. They run for $32.00 at Advance Auto
Old 09-04-2007, 08:21 PM
  #45
dnd2984's Avatar
any info on Beck Arnley Axxis metal masters, pads for the front. I really to thrilled with the Akebono. Tirerack said I can return them but need to do it soon so I have to buy pads locally. I found these http://www.partsamerica.com/ProductD...pe=219&PTSet=A
Old 09-04-2007, 08:25 PM
  #46
dnd2984's Avatar
they also have these http://www.partsamerica.com/ProductD...pe=219&PTSet=A
Old 09-04-2007, 10:46 PM
  #47
Riq
Riq's Avatar
Like 01tl4tl said, Racingbrake+EP300 or Hawk pads. They're not cheap but they have gobs of stopping power. They also happen to be 100% homegrown all American parts from the ground up. I was fed up with the wobblies and soft braking on my 02 TL.
Took 01tl4tl advice and splurged on Racingbrake+Hawk (EP300s weren't released yet), and also convinced him to drive 50+ miles to do the job. Absolute perfection on the install
Tried the brakes out after the install and it scared the crap out of me. If I hit them any harder, I think my rear would have lifted off the road.
Old 09-05-2007, 01:21 AM
  #48
01tl4tl's Avatar
Its not really exciting until you empty the seats of everything under braking- NOW you're finding out how well they stop when you realllllly need them.
My chiro couldn't figure out how I kept messing up my shoulder- ahem- seat belt~~~
Old 09-05-2007, 08:06 AM
  #49
dnd2984's Avatar
ook ok I will order the hawks. What are the EP300 I was going for the HPS.
Old 09-05-2007, 08:19 AM
  #50
dnd2984's Avatar
wait my issue is I need the pads now. So I can return the Akebonos.
Old 09-05-2007, 10:43 AM
  #51
Ellcapitan's Avatar
ET300s are comparable to Hawk HPSs. ET500s are comparable to Hawk HP+s. At least, that's how I understood it...
Old 09-05-2007, 07:47 PM
  #52
01tl4tl's Avatar
Thats correct Lcap
ET300 = 30% track style driving 70% normal human style driving, replaces HPS
500 is 50% escaped mental patient and 50% azine member driving style, replaces HP+/Blue
You order the RacingBrake ET series pads from azine vendor MrHeelToe
PM me for further tech info!
vpasla1
09-17-2016 07:24 PM
kb1rl
09-30-2015 10:17 AM
xsilverhawkx
09-28-2015 06:51 PM
Quick Reply: OE or aftermarket rotors
