Odyssey Battery size help
I'm Cool
hey, i need to replace/upgrade my battery. I am interested in the odysseys because their lighter, smaller and its dry cell. The problem i am having is which odyssey to get. I did my research, and found that the PC925 is the closet fit with very little modification to the OEM battery tray. So do you guys think i should i get the 925? or something else? thanks in advance
Kilos of yayo in
I used the PC1200 in my car. You won't have to modify the battery tray but you will have to use a riser as it is quite a bit shorter then stock battery. Also that battery meets the CCA rating that our car requires.
Kilos of yayo in
http://gallery.bcentral.com/ProductD...95&PID=3653513
Thats the best price I could find. I got mine at batteriesareus but it looks like they are no longer a dealer as they are not listed on the site anymore. Trust me its worth it! The stealership did something to my battery and it was reading 4 volts! The bastards were going to toss it but I did not let them. Following the procedure on batteriesareus site I was able to get her charged back up. Been using it for few months after that and it is still going strong reading 12.8 volts.
Kilos of yayo in
Hmm yeah just noticed that but it should be the same one. Looking on Odysseys site they don't make other versions of the battery. Guess I would maybe call and verify but as long as its the 1200MJT then it should be the same one.
I'm Cool
thanks for the link. I remeber mr.heelfoot or something has a group buy for this battery. I will contact him later to see if he sitll have some left
