Odd Scraping sound in Front Left Brake Tire...
9th Gear
I was wondering if anybody has ever had a similar issue as I am having with my 2002 TL-S.
When I am driving, I ocassionally hear this strange scraping sound in my left front tire well. It sounds like (and I am doing my best here) two pieces of metal scraping each other as a pair of scissors would sound, but more in a continuous manner. The sound does come and go, and is more offen triggered by a wavy road and is generally only audible @ speeds greater than 35 mph. When I hear the sound, I apply a little pressure on my brakes and the noise goes away for as long as I have my foot on the brake. Sometimes the noise goes away after that, but most of the time it follows me.
I have 114,000 miles on my car. Replaced rotors, replaced brake pads and did a full brake bleed @ 70,000 w/ Powerslot rotors and EBC Greenstuff pads and some Pep Boys brand brake fluid. I've replaced my tires @ 105,000 miles and had an aligment.
I am considering just replacing the rotors and pads to see if that will resolve the issue, but it seems like a sizable investment if I can get away with not doing that for another few thousand miles. Any thoughts/advice will be much appreciated.
I should add that while I am no mechanic (obviously), I do not see any visable issues under the wheel well....
pull the wheel and look at the brake pads
Could be a wear indicator bar
40,000 miles is a lot out of front pads- especially when you have slotted,drilled or similar rotors as the many edges make for good knives against the pad
9th Gear
Ahhh...I see what you are saying.
Next question...because I am in a pinch, anybody know of a retail store in the Bay Area that will sell me some EBC front GreenStuff's over the counter?
I think I have a spare set of rotors at home in my abyss of a garage, but incase I don't then anybody have any recommendations on where I can get some rotora's or Powerslots (fronts only) over the counter as well? My steering wheel vibrates when I brake so I assume I need to replace them. I would just turn them, but I am seeing some minor cracking in them as well...
BLAST...
BLAST...
I would switch to Hawk HPS pads available locally at PepBoys
Often the pads get a glaze/build-up on them which can sometimes be fixed with a high speed method, but GUESSING, because you live in SF, that the brakes get use a lot on hills and traffic.
Depend on the actual condition of your rotors. Have a local shop inspect for you
The "cracking" may be normal wear
If you put new pads on the old rotors- clean rotors with 150 grit sandpaper and wash with soap and water- otherwise-brake noise for sure
08 Civic SI
i got the same sound on my slotted dimpled rotors and ebc greenstuff(about 7k on um). no luck finding the source but i changes tone when i turn the wheel a bit,and stops at a certin wheel postition which leads me to belive somthing is rubbing, try taking it all apart and see whats scraping.thats what im gonna do.
I have a promblem simular to that, only difference is that when I am driving at about 10-20p/h I hear sound like my calipers rub against the rotors. I don't think its the metal piece, because it would of made squicking sound. Is it something that could be caused my warped rotors?
Thank you for your help in advance,
~PETE~
~PETE~
Its pretty difficult to warp a quality set of rotors like yours without very some exteme driving.
Whenever there is a noise in your brakes, remove the wheel and inspect!
It is necessary to remove the pads to really check them - condition of their
active surface as well as total pad thickness remaining
Its more often a case of pad glaze than rotor warp
With high performance parts- got to use them or they complain.
Make sure the calipers are properly greased and the bolts at correct torque
If all parts check out ok - then you can do a high speed re-bedding to remove the glaze and get the pads working properly again
nuldabz
09-03-2015 05:49 PM
