Octane & HP
Old Jun 25, 2001 | 12:21 PM
Cool Octane & HP
I was reading the July issue of Motortrend and they had a review on the Honda Odyssey mini van. I believe it has a 3.5 210hp motor in it. Anyways they put regular unleaded in it and they lost 5 hp and 12 lbs of torque comparred to using 91 or higher octane.
Just another FYI.
Comptech Exhaust
Comptech Filter
Piaa 1700x
H&R sport springs
18" C2's coming in July..
Old Jun 25, 2001 | 04:22 PM
SL1200MK4's Avatar
Post
Higher octane will give you more power... no doubt about that...
Old Jun 25, 2001 | 07:09 PM
Guest
Guest
Posts: n/a
Thumbs down
Sounds like something Motortruck would do.
Old Jun 25, 2001 | 08:09 PM
LagunaTL's Avatar
Post
i think it depends on the design of the engine. if you put regular unleaded in a premium only engine you might lose power, but using premium gas in an engine designed to burn regular unleaded will not give you additional power. feel free to correct me if i am wrong.
Old Jun 25, 2001 | 08:21 PM
Bitium's Avatar
Retired MOD
Wink
I don't think it would make a difference, since a higher octane is used on high compression engines because the higher the octane the less chances the fuel to ignite with compression. Like a supercharger, you have to used 93 octane or higher. My friend that has a 857hp Lexus and he has to put 110 octane or higher on his car. The octane rating of gasoline tells you the amount that the fuel can be compressed before if spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want have happening. Lower octane gas (like "regular" 87 octane gasoline) can handle the least amount of compression before igniting. So by putting 87,89,91,93 octane gas WILL NOT INCREASE OR DECREASE HORSEPOWER Hope this helps.
San Yasin
Sep 29, 2015 10:52 AM
NSolace
Sep 3, 2015 08:14 PM
05TSXCALI
Jun 30, 2005 11:40 PM
d.brandusa
Jun 22, 2005 11:53 PM
mrsteve
15
Jul 20, 2004 08:44 PM
