Obdii
Old Aug 2, 2004 | 06:02 PM
cscottyr's Avatar
7th Gear
Obdii
Hey Guys,
I'm a newbie - and I just want to find out how to get to my OBDII serial connection - Anybody out there know how to get to it. Thanks in advance
cscottyr
Old Aug 2, 2004 | 06:16 PM
TLMugen's Avatar
I'd rather be driving:
It's behind the little removeable panel between the seat heater buttons.
Old Aug 2, 2004 | 06:26 PM
cscottyr's Avatar
7th Gear
Thanks TLMugen,
I just found it - it was a P0420 - catalyst below threshold bank1 - Is that the fuel cap not on tight enough code?
cscottyr
Old Aug 2, 2004 | 06:50 PM
TLMugen's Avatar
According to the service manual:
P0420 - Catalytic System Efficiency Below Threshold
Note: If some of the DTCs listed below are stored at the same time as DTC P0420, troubleshoot those DTCs first, then recheck for DTC P0420.
P0137, P0138: Secondary Heated Oxygen Sensor (secondary HO2S) (Sensor 2)
P0141: Secondary HO2S (Sensor 2) heater
1. Reset the PCM
2. Start the engine. Hold the engine at 3,000 rpm with no load (in Park or Neutral) until the radiator fan comes on.
3. Drive approx. 10 min. without stopping on a highway or freeway. Your speed can vary.
4. With the trans in D5 position ('99 model: D4 position), drive at steady speed between 50-62 mph (80-100 km/h) for 30 sec.
5. Do step 4 three times. Between each procedure, close the throttle completely for 1-2 sec. If the engine is stopped during this procedure, go to step 3 and do the procedure again.
6. Check for the three way catalytic converter (TWC) test result with the scan tool.
Does the scan tool indicate FAIL?
Yes - Check the TWC. If necessary, replace the TWC.
No - Intermittent failure, system is OK at this time.
Old Aug 2, 2004 | 07:38 PM
cscottyr's Avatar
7th Gear
Thanks TLMugan,
You have been very helpful tonight!
cscottyr
mada51589
Jan 9, 2025 04:40 PM
schen72
1G RDX (2007-2012)
Jul 25, 2011 03:05 AM
DJBOMBERMAN
1G CL Problems & Fixes
Mar 9, 2010 09:04 AM
jcooper97TL
1G TL (1996-1998)
Sep 15, 2008 04:22 PM
red00tl
Nov 13, 2007 02:47 AM
