Nuts/bolts for Comptech Axleback Exhaust required?
Liquid Ice
I just bought a Comptech Axleback Exhaust from a member and he shipped the axleback exhaust, but absolutely no bolts or washers. Are these required or can I get away with using the stock bolts/washers that are already holding up my exhaust?
Thanks!
Thanks!
Blown is Best
You need nuts, bolts, and washers. Factory muffler flanges have nuts welded to them so when you remove, you'll only have bolts. Not sure what size off hand. Just take one of the mufflers with you to the hardware store and get 4 bolts, washers. lock washers, nuts. No gasket to worry about - flange to flange mount.
just go to any hardware store and get them, thats what i had to do when i got them NEW from comptech!
Liquid Ice
Yeah, I got the directions from Comptech's website. Needed 10mm bolts/nuts/washers. Got 'em all from Lowes (Home Depot had a crappy selection, their bolts and nuts didn't even have the same threads!).
Everything went on easily, just removing the bolts from the original mufflers was a pain in the butt.
Liquid Ice
Originally Posted by goldendragon576
spray some WD-40 and let it soak first, then find a long pipe and use that for extra torque. I did that and it came right off.
joflewbyu2
08-18-2019 10:38 PM
joflewbyu2
10-08-2015 11:16 AM
