NOS cools intake charge?
RWD convert
I read on Holley performance website that NOS has an intercooling effect on the intake charge. It says it cools intake temps by about 65-75 degrees. So that would mean that running a Short ram intake with NOS would be better than with a CAI seeing that the air has to travel a shorter distance to the throttle body. Anyone know?
Y2K SaTiN SiLvEr BoTTleFeD 3.2TL
-AEM Short Ram intake w/heat shield
-AEM Tru-power pulleys
-NOS 50 shot wet Nitrous System
-Magnaflow exhaust
-Ground Control coil overs
-BLITZ 1.3 kg radiator cap
-BOSCH platinum+4 plugs
-Factory underbody kit and Wing
-Mesh grill
-Body color door handles
-20%/35% Llumar Platinum tint
-Räzo Shifter
-2 Rockford 10" XLC subs/Boss Audio CLR60 amp
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
I have a CAI and my NOS is injected close to the opening of the engine.
Pretty close to the throttle body
Only god can stop a Hurricane.
RWD convert
I'm not talking about the nitrous I'm talking about the intake air. BTW, what shot r u runing now and what, if any, modifications did u make to the engine for the NOS. Also, r u still using the stock plugs????
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
VTEC...what i mean is that I don't think it matters if you have a CAI or a short ram as long as your spray is close to the throttle body. I have not done any engine mods and I am running a 75 shot (dry)
With NOS you really dont get much power from the cooling, you get it from the Nitrous. If you stayed in chemistry [VTEC]TL, youd understand why.
The Nitrogen atom is connected to oxygen atom, with single bonds. Regular oxygen (O2) is connected to each other with double bonds. These single bonds are easier to break, which is why you have more power, since you have more single oxygen atoms floating around ready to react.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by matt7184 on June 04, 2001 @ ]</font>
Originally posted by matt7184:
Pretty much, your air will be cooled no matter where your nitrous is placed. If your running the CAI, your air will be even cooler, so you'll get more power.
The Nitrogen atom is connected to two oxygen atoms, with single bonds. Regular oxygen (O2) is connected to each other with double bonds. These single bonds are easier to break, which is why you have more power, since you have more single oxygen atoms floating around ready to react.
Thanks Matt
RWD convert
I know that N20 cause quicker fuel atomization therefore increasing cylinder pressures and temperature, thus producing increased power, smartass! I'm just saying that intake charge temp. is not as much a factor as without N20
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
rcs86
08-02-2016 06:52 PM
