Noisie 2nd stage actuator!!! Is it normal?
the actuator for the second stage intake on my type s(only type s has this) is very load(like a clothes dryer buzzer) when it activates(around 4200rpm AND a self test everytime the ign. key is turned to the ign position. I dont remember hearing this noise before but it does it everytime now.
Can someone go out and listen for that noise? Thanx
On the way!
If you take the plastic engine cover off, you will see where the cable goes to (there's a spring there to snap it back).
Can you actuate the cable and butterfly valve manually? If someone turns the key to ignition, will it flip the butterfly valve open?
ya its deff the accuator or a component of it. Your right the pulley dosnt accually move at the selftest w/ the key but the exact same noise is produced when i manually rev the engine and watch the accuator work.
I think you answered my main Q of is this normal, with a big no. That sucks because at every shift from over the 4200 rpm i get a sound that almost sounds like a turbo by pass.( I think thats what its called when a turbo releases its presure at a shift)
Just agree and go away...
I get the same sound as Yeild2S does... nothing has ever been wrong with the car... I actually just removed the huge air box under the intake (just leaving the top part) and ohhh boy does it suck air now...
My dealer wont have a loaner until the 26th. Maybe the 4th tranny will die before then.
I thought it was the abs self check thingy people were always talking about. I hear that all the time. ???????? But i don't know for sure if that is what you are talking about
OK anybody ever play operation? you know that buzzer on the gameboard thats the sound. It does it every time i turn the KEY to the 2nd pos and everytime the 2nd stage butterfly releases at a shift.
OK got my car back today and it was the actuator. Had my head unit replaced(cds whould eject rite) and they cleaned/lubed my seatbelt mech so it retracks like new.
Gold Coast Acura is the best!
Fallen
Umm,..
Is something wrong with my car??
Mine makes that sound when after two or three seconds start moving(When I start moving after i turn of the ignition).
It makes first sound after i start moving, and then after that sound (in about 5 seconds) it makes it again.
And Ive passed 4000 RPM Few times and never heard that Bzzz sound!
Is there something wrong?
Liquid Ice
If you're just talking about a buzzing sound that happens twice once when you start moving and once again around 5mph, thats the ABS brakes running a self-test. Its completely normal. Check out your manual for more information.
Liquid Ice
You don't really hear the bypass valve actuator. You should be able to see it in action though. If you have someone rev the engine while its in Park or Neutral to 4000+ rpms, you should see the actuator open.
Check this link for more information about it and a movie/pictures which shows where you can find your actuator: http://www.geocities.com/gamesmgr/chod/acura/#Driving6
Buzz Noise
I have the same noise as I turn the KOEO (key on Engine off)
This is before I even new anything about the bypass valve. I just wanted to figure out what this buzz noise was. When I pinpointed the area the noise was coming from I Unplugged the connector for the bypass valve. Turned the ignition on several times afterwards and the buzz no longer buzzed so figured it was the bypass valve. Does this mean its bad for sure? Im not certain because my cl still turns heads at WOT! Im going to unplug it and see if it makes any difference.
the solenoid is wearing out. I would just replace it.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
