Noise from the sunroof area
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hello everyone,
I'm getting this annoying virbrating sound from the sunroof area while driving on bumpy roads or when the stereo is blasting.
Can someone please tell me where the hell is this noise coming from and how do I fix it?
Thank you!
TL'00
Thank you!
TL'00
take it to the dealer for it. they put some teflon like tape where the rubber seal is mine did that and after it stopped
I find that if i open it a crack then the sound goes away. I had this problem with my previous car also. It was a Galant. If you just tap the open button for a second the roof opens up a little but not enough for air to come in. I think that when the roof is completly shut it makes tends to make noise.
Yeah the dealership will fix it if you complain. They're just going to clean it and give it some lube.
Better off just doing it yourself. Get some plumbers grease and a rag.
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Thank you for your help. I will try to take care of the noise myself, if not, I will go to the dealer...
bye
bye
A bit of silicone grease applied to the weather stripping will solve the problem. Be sure to use silicone grease because it will not dry out the rubber like petroleum grease will.
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
