Nitrogen for your tires?
Has anyone ever heard of this?
Yesterday I was watching the news and they did a segment on this. A local tire place for $25 will deflate all your tires and put Nitrogen in them, and then you get a free lifetime of the tires inflation to the correct PSI.
Pros:
-Nitrogen doenst expand and contract like air does, so the PSI wont change with temperature.
-Nitrogen leaks through the tire at a much lower rate of speed then air does.
-If the tire is low you can mix it with air until you can reach a place to put all nitrogen in your tire.
Cons:
-Most gas stations dont have Nitrogen fill up stands.
I was wondering if anyone here has actually tried this? I want at least try it but my tires need replacing soon so I dont see much of a point. Has anyone even heard of this?
Pros:
Cons:
and then you have to go to Costco anytime you may need a presrure adjustment
For the normal human it doesnt do anything to improve mileage or tire wear
For racers and those who think they are race drivers- it does help in those extreme tire temperature conditions
I keep a 12volt compressor in the garage and when the temp makes big changes I adjust my tires at home
I had my tires filled with nitrogen - until I had the A service done. Dealer rotated tires and left 34 psi in the now rear tires. I went back and they said they inflate to 32 psi for all TL cars - even S types. Anyway I went to Discount Tires and they filled tires to 35/32. I now have a mix.
VQ: How do you like it compared to regular air?
01TL: Good point that would be a pain and like I said it early it was a con because that would get annoying.
donc: How does your car do with a mix?
bibledriver: I do understand that Nitrogen does expand and contract but they made it sound like it was basically so little you wouldnt be able to notice a diference.
'06 NBP TL 6spd
Originally Posted by realfresh
Most people get it because it's usually a fill and forget where you don't have to worry about your tire pressures...
i duznt ride differently with nitrogen, but i notice on the tpms that the pressure stays relatively stable, and that i have to fill up my tires with nitrogen less often then i had to with air
Something is missing...my
Good tires really require little maintenance. Filling of a tire often is an indication of either it being so old that it is leaking through cracks or that there is a puncture somewhere. If your tires require frequent filling then check them out at a tire shop.
It is good to periodically check tires, old addage says "at every fillup." Maybe I don't check mine that often, but with lo pro tires where it is harder to detect leaks visually, checking is important. Underinflated tires get heat damage.
Air, Nitrogen, Dry air . . . Whatever pleases you. Just check them often.
Originally Posted by timberland73
I've got Nitro in my tires too. Don't feel any difference but I got it done for free so who cares.
Sorry, I worded that wrong. I meant I didn't notice a difference. I didn't see any increase in fuel economy or anything else "special" mentioned in the brochure. But my techs said it was free to employees so I made the switch.
Nitrogen isnt a miracle gas that does all sorts of things to your tires like the techs make you believe.
99 TLS6 08 TL
Just so everyone knows I'm not trying to start an arguement or that I'm talking out of my ass, hers's the link to NitroFill. www.whynitrofill.com. I just read and said cool.
In any article you read about Nitrofill it says it increases tire life and gas mileage. All I'm saying is there was no difference. I'm not saying Nitro is a miracle gas. Nor did I ever. I just have it in my tires.
99 TLS6 08 TL
Originally Posted by fsttyms1
It does, but you know how it does it?? It does it by keeping the PSI at a stable PSI. It doesnt fluctuate like air. The exact can be done with air by checking often and adjusting the ties properly. There is nothing in nitrogen (other than it bing dryer ) that makes them last longer or increases mileage. People need to be aware of how or why they claim it does what it does.
I know exactly what and how it does what it does. All I said was I didn't notice a difference. Get over it. Who cares. Everyone knows that you know everything about cars. You don't have to prove it by arguing with me about pointless BS.
And i quote
Id suggest cooling it.
99 TLS6 08 TL
where did i start arguing with you about pointless BS??
And i quote
you stated that and all i was trying to do was clarify (mostly for those who dont know) why they claim what they do, and its not something you should be able to "notice"(unless you dont maintain your car and your psi is already low to begin with).
And i quote
CostcoFanAUS
09-18-2015 06:05 AM
