New tires w/factory rims...help?
Right now, I am not buying rims because of other priorities I want done to my car, anyway, would I rub if I get say 225/55-16 tires on factory rims? Have anybody here done this? Thanks again,,,,,
CBS-
01' 1 week old Black pearl TL
Mods a comin'
CBS-
Mods a comin'
The Doctor
yeah many people have done it and the majority of people said there is no rubbing even after comptech springs.
i am actually thinking about the same thing. but i might get wheels later (like 2-3 years later).
nope, it doesn't. it looks a lot better, too.
Moderator on Acura-TL.com Forums
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Nebraska Legal Darkest Tint
Goodyear Eagle HP Ultra Plus 225/55/16
Photos Of My RED HOT TL
Wood Trim Set
Gutter Guard Grill
Thanks guys! I personally do not want to go lower than 55's because I do like the ride of factory tires, which of course, you know is 60's. I will not be racing anyone, but I just want to keep the factory luxury look!
CBS-
CBS-
I talked to some people work at tire shops. They actually told me that it is not a good idea to put 225/55/16 on a 16' 6 1/2' rim. He told me that the rim not wide enough for the time.... But that's just what they said. Maybe they just want to sell me a extra set of rims...
But I talked to two different Acura dealrs, they both told me that you might get bubble on the side of your tire....
That's what crossed my mind too, and that's why I waited to do the whole package. 225 on 6.5 inch rim, that would worry me.
1999 Firepepper Red
Under Body Kit/Rear Wing Spoiler/26 Piece Wood Grain Console/BurlWood Shift Knob/
30% Smoke Tint/Comptech Sways & Springs (not installed yet)
More Pics
1999 Firepepper Red
More Pics
Guest
Posts: n/a
The rule of thumb for wheel width is 70-90% of the tread width. 6.5 rims are about 73%. They fit fine and don't rub. They look great on the rims. Plus the wheels will be MUCH less likely to get scarred when your wife tries parallel parking with your L
2000 3.2 TL, Paper maps.
Naples Gold / Parchment.
225/55ZR-16 RE730s on OEM alloys.
205/55QR-16 Alpins on steel wheels w/covers (winter).
Pictures
1999 CR-V EX 4WD Auto White
1992 MR-2 5-Speed T-Tops 2.2L, Greddy SP S/S Exhaust
Pictures
I don't think anyone has had problems with 225/55/16 tires. When it is time to replace my tires i wheel get that size.
2000 Fire Pepper Red/ebony TL, non-navi. factory spoiler, std chrome wheels, 35% tint, comptech exhaust, wood trim kit...
Quiets ride
Quiets ride
I have had 225/55/16s on my stock wheels for over a year and a half. Not a single problem. If you're sticking with the stock wheels I would definately suggest 225s.
99 Silver TL, Navi, Foglights, Gutter Guard Grill
Guest
Posts: n/a
I would go with 215/55-16, but the tires I wanted aren't available in 215's. Many aren't! But if they were, I would probably get 215's over 225's next time.
Pictures
Pictures
dude, just go with 225/55/16s, stop debating... there's no point. if you put on 215s, your gauges will be off a lot, that's a no doubt, and there's no problem at all with 225s
Wood Trim Set
Gutter Guard Grill
Wood Trim Set
Gutter Guard Grill
Originally posted by 99WDP:
The gauges aren't off a lot with the 215's. Check a tire size calculator http://www.miata.net/garage/tirecalc.html and you'll see that the speedo reads 1.45% too fast. At 60mph that's only .84mph, no problem.
It is definitely true that you will be adding some "Phantom mileage" with the 215-55-16s since it has an overall diameter 9.5mm less than the stock tires (circumference will be less than the stock tires by 29.85mm). But effectively what that will add up is, approximately about 750 additional "phantom mileage" on your odometer readings at 50000 miles. So your car's warranty will expire 750 miles before the car has truly reached the 4yr/50000 mile warranty limit.
The 225-55/16s are closest (to the stock tire/wheel diameter), since the overall tire/wheel combination diameter is "off" from the stock diameter by just 1.5mm....which is no biggie since if you have been using the 225 tires for a while, it would hit the stock tires' diameter perfectly (225s has a diameter 1.5mm more than the stock tires).
I would probably think seriously about adding 215/60-16s since that combination has a diameter that is slightly larger than the stock tire/wheel combination diameter....I think the Michelin Pilot XGT-V4 All-seasons are available in that size....your odometer would be slightly "off" but then you will not add any "phantom mileage" to the car...you will actually "gain" some additional mileage....
just my 2c
2000 Naples Gold 3.2TL/Navi - Factory Stock but with up-graded tires
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by hunter001 on March 05, 2001 @ ]</font>
CostcoFanAUS
09-18-2015 06:05 AM
