New radiator, now transmission problems?
Old May 7, 2017 | 07:58 PM
BrookeDawn's Avatar
3rd Gear
My uncle and I put in a new radiator the.other day, now I am having transmission issues could they be connected? My D light is blinking and tranny not shifting well. I'm about to check fluid in a minute.
Old May 7, 2017 | 10:29 PM
Skirmich's Avatar
Depends on what model year you have..
My TL-S for example does not have ATF Lines going into the radiator.. While I believe the 1999 model did have and I am not sure about 00-03 base models.
Old May 7, 2017 | 11:22 PM
BrookeDawn's Avatar
3rd Gear
Its the 2003 TL. Automatic transmission
Karanx7's Avatar
Unregistered Member
Only the 99 TL had the ATF warmer
Old May 7, 2017 | 11:25 PM
BrookeDawn's Avatar
3rd Gear
Also I did check the fluid and it was WAY over full. I haven't added any fluid. I had a drain and fill done on tranny in september but I would think it would have shown signs of an issue way before now if they had put too much in it then. I read a little online and I seen some people say something about the tranny's temp gauge... I don't know a lot about cars but I assume I should learn cuz this car has given me nothing but problems. Lol
Old May 8, 2017 | 06:03 AM
Nicks2001tl's Avatar
Start with draining the fluid....Obviously.
Pull all of it out. A little over 3 quarts should come out and then refill to the center of the line, make sure you drive the car a little before checking the fluid and it is on an even surface when checking the dip stick.
You should have a little fluid left over when done and dispose of extra fluid properly.
Old May 9, 2017 | 10:49 AM
Originally Posted by Nicks2001tl
Start with draining the fluid....Obviously..
this.
ATF-DW1 Honda/Acura Fluid
Old May 12, 2017 | 04:36 PM
Kris9884's Avatar
Yep. Whether it be this car or the next, its always good to know how to diagnose and/or fix your own problems. It'll save you thousands of dollars and countless hours of waiting on mechanics to figure things out for you.
