New Owner
4th Gear
New Owner
Just Want To Drop In And Say Whats Up To All!! What A Great Site.
Im New Here And A Proud Owner Of 2003 White Tl-s With 20,000 Miles. Im Just Wondering, My Car Vibrates, Shakes, Whatever Tou Want To Call It At High Speed, When Im Approaching 60-70mph And It Worsen After 80. Any Idea Whats Causing This?? Brought It To The Dealer, And Cant Figure Out Whats Wrong, But They Did Resurface My Rotors And Change My Pads For Nothing.... Thanks.
Former Sponsor
Welcome to the forum mate. The only thing i know about that issue is a bent wheel. I use to have 19 inch ones on my TL and the thing would shake like a mofo at 80 and beyond, switched to new wheels and it was fine. Check with ur local tire shop, may be ur wheels just need to be balanced, see if that fixes the problem hopefully it will. WHile they are at it , ask them if they can check the wheels for any cracks dings or repairs as well. Later.
shake.
Get the high speed balancing done on all 4 wheels. Sometimes the wheels are off balance a little and the problem becomes more apparent an high speed. I am assuming that all 4 wheels are the same brand and they are rated accordingly. Also there are no visible problems on the wheels.
4th Gear
Thanks For Your Warm Welcome. Now, About The Issue, I Had Done A Four Wheel Alignment, Did The Balancing And All. But The Car Still Shakes Or Vibrate. Should I Get New Rims Or Should I Swap The Back Wheel With The Front? Appreciate All Your Help.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
