New IAC Valve
New IAC Valve
At 117K miles my 2001 Acura TL's IAC valve took a dump.
About 1 week ago the check engine light came on and the rev's were hunting up & down. I reset the computer and everything was fine for a week and the same thing happened. I had the code read at Autozone (P0505).
I decided to fix the cause of the problem this time and pick-up a new IAC valve at the Stealership. $153 bucks later and 45 minutes of my time and it's all better.
When I had the throttle body off I noticed a puddle of oil in the upper air manifold just past the throttle body. Some of the oil residue was evident on the lower part of the throttle body gasket. I cleaned up the oil and put everything back together.
The last time I noticed the oil was at 87K miles when I cleaned out the carbon in the upper & lower air mainfolds.
I was wondering if the oil shortend the life of my IAC valve. I suspect it didn't but it made me wonder anyway.
COTM Coordinator
I had the same problem with mine, but I just took apart the throttle body and the IAC valve and cleaned everything. I thought I was going to have to buy a new one, but after cleaning it, it worked great.
Originally Posted by randomwalk101
just clean the old one first..more than likely it will work...worked for me before.
