new car,what to do first?
Old Oct 15, 2010 | 09:21 PM
teamleader's Avatar
4th Gear
Hi,I just bought a 2001 tl.I dont have any vehicle maintance history.It has 78,000 miles on it.What should I do first?I was thinking seafoam,spark plugs,oil change?What kind of transmission maintance should I do.What brand fluids?Anyone use Amsoil products?Thanks
Old Oct 15, 2010 | 11:31 PM
01tl4tl's Avatar
welcome to the forum
have a read down the main thread titles, and the special section- problems and fixes
most questions are already there
the diy list section is 3rd item down the main list for gen2
register with acura as the new owner 1-800-382-2238x5
ask if all recalls are completed
register here and get online owner book -lots of trick systems and tips for the TL
http://owners.acura.com/registration...erstepone.aspx
you can access your cars history there and store the radio security codes too
is the external oil jet kit installed on the trans top center?-
has the trans been replaced?
you can tell that by looking at the bolts on the trans end--painted blue is acura
warranty unit
if its original stay with 1, 3 qt change using honda z1 atf
read about probs of high miles trans and full capacity changeouts--not good
use the right plugs-not cheap but the best for the car= ngk Iridium
Old Oct 15, 2010 | 11:35 PM
01tl4tl's Avatar
engine oil and filter is your choice--everyone loves whatever they choose!!
5w-30 normal areas ,,overnights below freezing use 0w-20 for better cold start protection
Always use 91 octance gas or higher, never lower
its time for coolant change, brake fluid,ps fluid
and be aware the `105`/timing belt water pump job is due at 105 or 7 year-whichever first,,time is bad for rubber belt
another not cheap item, but the only major service the car gets
Old Oct 15, 2010 | 11:43 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
That all sounds good. Make sure to use SeaFoam in the crankcase, throttle body vacuum port, and gas tank. I use Amsoil for engine oil and ATF. Great stuff.
Old Oct 16, 2010 | 12:14 PM
gold2003tl (90)'s Avatar
2003 TL-p
^ only use honda ATF in these trannys.
Old Oct 16, 2010 | 12:24 PM
jjashaa's Avatar
Avant Garde Wheels
myeh..
using Redline D4 ATF in 7th Gen Accord Auto.. doing fine here.
its actually been recommended to me from a 3G-er
Old Oct 16, 2010 | 12:28 PM
2003 TL-p
i have't heard any feed back from someone using Redline atf on a 2g TL. maybe its good, i dont know.
Old Oct 16, 2010 | 01:07 PM
jdjohn84's Avatar
I can speak for Amsoil. When I got my TL last December, I noticed an occasional shudder between 2nd and 3rd. I changed to Amsoil Synthetic Universal ATF, and the shuddering stopped. It also shifts firmer than before. It went from a luxury shift to more of a performance shift. I'm not saying the car's 'performance' increased, but it's a firmer shift than before.
I did the change in ATF gradually. I did standard 3.5qt changes about a month apart instead of the 3x3 method. So far, so good (knock on wood). I pay homage to the tranny gods. I have a 2.5 gallon jug just waiting for more changes. I was going to use it on my son's Ford Escape, but the shifting problem turned out to be something else. Frankly, that POS is not worthy of Amsoil.
Old Oct 22, 2010 | 10:21 PM
Tomapapi's Avatar
Just borrowing this thread from teamleader
How often should the transmission fluid be changed? My TL has 178K. Tranny was replaced 40K ago.
Old Oct 23, 2010 | 10:37 AM
01tl4tl's Avatar
with 40 on it- start a yearly 3 qt drain and refill
Old Oct 24, 2010 | 03:18 PM
jdjohn84's Avatar
^X2 ... or every-other oil change.
Old Oct 24, 2010 | 05:11 PM
01tl4tl's Avatar
thats what I should have said-- some drive way more than others,,
15 a year is average put on the TL here,,so every 2 oil changes...do trans
its useage went down since the introduction of the 2 wheeled honda to the garage~
Old Oct 26, 2010 | 07:45 PM
teamleader's Avatar
4th Gear
changed the oil,seafoamed(that was awesome)took it down a back road at 100mph.the front tires are almost bald so I didnt want to push it.
Old Oct 26, 2010 | 07:53 PM
teamleader's Avatar
4th Gear
also changed the sparkplugs,ngk iridum
Old Oct 26, 2010 | 08:38 PM
01tl4tl's Avatar
did you get the TB air plate too?
Old Oct 31, 2010 | 08:35 AM
teamleader's Avatar
4th Gear
no I didnt get the tb air plate.where is it?what do I do?THANKS
Old Oct 31, 2010 | 11:38 AM
01tl4tl's Avatar
I dont think we have the air plate in the seafoam diy--
remove top engine cover plastic
remove air tube from air filter box to engine
you are looking at the TB open end-
spray the round plate inside
operate throttle via assembly there, it opens plate to get the back and edges with carb cleaner
wipe up runoff
wd or silicone spray or deep creep all work well for the lube on spring assembly
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
