Need Quick Help!
Old Aug 22, 2008 | 07:50 PM
Never Summer's Avatar
Need Quick Help!
Hey guys. If I'm taking out my stock suspension but leaving it together, do I need to use a spring compressor? Someone with knowledge please text me the answer, 3035493973 is my number. Thank you all very much.
Old Aug 22, 2008 | 09:35 PM
Any one have any tips for removing a nut that is stripping as I try and remove it?
Edit: Anyone local to the DTC if you're able to help out with the install tomorrow let me know, I can pay you for your time.
Old Aug 22, 2008 | 09:43 PM
Mista Juice's Avatar
which nut is it?
Old Aug 22, 2008 | 09:56 PM
Originally Posted by Mista Juice
which nut is it?
I'm having trouble with two, one being the inner-most 14mm nut on the front suspension, and the other being the rear 14mm nut on the rear suspension.
Old Aug 23, 2008 | 11:43 AM
01tl4tl's Avatar
for your original question
When removing the shock assembly from the car- it stays together , no use of spring compressor required
Only if you are taking them apart to replace the shock or spring, or move parts like the tophat- to a new shock assembly-
Working on the bench/ground, then you need to deal with the spring tension
Never try to remove that top nut on the shock shaft without comnpressing the spring!!!!
At minimum, its a trip to the dentist for new front teeth- or maybe the ER for chest-rib injuries
Any stuck nuts should be treated with wd type spray- cooking oil if thats all you have~
Make sure you are turning it the right way, ie leftie loosey, use a longer bar to get leverage
Old Aug 23, 2008 | 07:51 PM
Thanks for your help. Using some tools I didn't have me and a friend got my new suspension put it in a few hours.
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
