Need a Non Vibrater Solid Mount
Old Apr 25, 2008 | 01:33 PM
Seikoja's Avatar
Replace the back mount and broke it within the same year n no its not because of heavy right foot or too much sports shifting . lol. so im not buying back another stock back mount i need to kno if you the professionals at acurazine can recomend a company that sells a solid back mount that wont get me too excited watching my girl friends boobs jiggle at a light, have to save that excitment for lata.
Old Apr 25, 2008 | 03:36 PM
acutee's Avatar
I guess oem mounts are as good as other mounts. Maybe you should add engine dampener to protect the mounts from engine over shaking and for better performance.
Old Apr 25, 2008 | 04:34 PM
phipark's Avatar
Not Asian
You can check out the Innovative mounts. There's a thread in the 2nd gen CL section.
Old Apr 25, 2008 | 04:39 PM
phee's Avatar
I got the Shifts
couldnt he take that mount out and use some sealant or something to make it hard and stiff and reuse it?
Old Apr 25, 2008 | 06:09 PM
MurdaZ's Avatar
some people were injecting more silicone inside and outside the mount.....
Old Apr 25, 2008 | 09:52 PM
Seikoja's Avatar
i dont think so its hydraulic
Old Apr 25, 2008 | 09:53 PM
Seikoja's Avatar
thanks man i will check them out
Old Apr 25, 2008 | 09:58 PM
Seikoja's Avatar
i dont think u understand i broke a honda factory mount within the same year off installation n i dont drive my car often. but a dampener doesnt sound like a bad idea
6MTUA5's Avatar
No He Can't
Yea I'm running the solid polyurethane Innovative mounts all around. Definitely an improvement over stock and a lifetime warranty. There are increased vibrations due to the mounts, though.
Old Apr 25, 2008 | 10:01 PM
Seikoja's Avatar
how bad u think it would vibrate if i just replaced the back mount
Old Apr 25, 2008 | 10:29 PM
6MTUA5's Avatar
No He Can't
Here's the original thread -- https://acurazine.com/forums/showthread.php?p=5808815
Here's the discussion of the CL guys about the mounts -- https://acurazine.com/forums/ramblings-12/nextel-i90c-193660/
Old Apr 27, 2008 | 01:39 AM
02type-s's Avatar
-Arsenic-
How bad are your vibrations? scale of 1 to 10, 10 being unbearable. lol. I want them but not if the vibrations are gonna drive me nuts. Does it make stuff rattle?
Old Apr 27, 2008 | 03:36 AM
TCM 01 CL-S's Avatar
Uses turn signals in my
02AV6 used premixed polyurethane for the record. Sounds like the OP has enough to watch jiggling, so no need for silicone.
Old Apr 27, 2008 | 11:34 PM
Seikoja's Avatar
Thanks guys really appreciate the help
Old Apr 27, 2008 | 11:39 PM
6MTUA5's Avatar
No He Can't
I would say less than a 5. It's only bad when I'm close to stalling. You know when the car starts to shake a little bit? Since you have the auto, you probably won't feel it as much.
Old Apr 28, 2008 | 09:28 AM
fsttyms1's Avatar
If you destroyed a rear in a year something was either wrong with it or all the other mounts are shot putting alot of stress on it. The rear takes way less abuse than the front.
Old Apr 29, 2008 | 09:33 AM
Seikoja's Avatar
na thats the thing i took all my work to honda everythin on that car is done at the dealer. they told me three of the five mounts was bad so they replaced the three with honda factory parts. when i changed my oil recently the tech told me yea its broken again so i need an alternative. i cut my tl loose everyonce in a while my onli upgrade is a safc dyno tuned but other wise from that i cruise. I spoke to p2r from the cl-s section and he said the innovative is a good choice just want to kno if any other choice.
Old Apr 29, 2008 | 09:36 AM
fsttyms1's Avatar
No. There is no other choice. Like i said, there had to be something wrong with it to begin with because the rear usually doesnt fail, especially in a year. Most are on their original rear and have been thru 2+ fronts. My rear was original on mine with 210k and it was still good.
Old Apr 30, 2008 | 09:51 AM
Seikoja's Avatar
Dont kno man just goin off what the tech told me. i mean the onli thing i can think off that could cause it is my tranny does get wierd from time to time but not crazy. He told me that he is a seen the back mounts go like that before. he had 07 odyssey's comin w less than 10k for bad engine mounts its said its not uncommon for the v6 models to break mounts so quickly. n just so u kno all the other engine mounts are fine.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
