Need A New Key for the TL
Old Apr 29, 2006 | 11:03 PM
illTL's Avatar
Ok, i made just a normal key at a key store for the Acura TL..and it would crank but wont start..then i was told because it was not programmed or something. THe dealership asks shit load of $ for new keys..so does anybody think the keys off ebay will work if i just get them made at a key store???
here is the link to the ebay site.
Acura TL Keys
please let me know thanks
Old Apr 29, 2006 | 11:05 PM
TacoBellSauce's Avatar
they wont start due to an immobilizer chip on the keys
u can buy those keys, get em cut for cheap and programmed at a dealer or home depot
Old Apr 29, 2006 | 11:18 PM
illTL's Avatar
so i buy them and get them prog. at home depot??? really at home depot? anyone know how much this costs
Old Apr 29, 2006 | 11:41 PM
i got keys for my nissan altima programmed at my home depot for $50
they jus plugged in a PDA into the OBDII slot and pressed a few buttons
u can also get the keys from them for like $30 more but not sure if its OEM
Old Apr 30, 2006 | 12:21 PM
fsttyms1's Avatar
If you do a search there is a DIY here on how to reprogram a new key to work.
Old Apr 30, 2006 | 09:06 PM
xyrcncp's Avatar
Hi, I'm new here. I'm looking around for instructions on how to program a new key since I bought my '03 TL-S used and only came with one key. I searched, but all I kept coming up with is instructions on how to program the keyfob, but nothing for the key itself. Any ideas?
Thanks!
Old Apr 30, 2006 | 09:26 PM
fsttyms1's Avatar
This is what i found. Try it out
What you need
1...your new key
2...a MASTER KEY (a key that works)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to
floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait.
the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light
is off, car should start.
Old Apr 30, 2006 | 09:57 PM
xanctus's Avatar
Kris, good info mate...thx I shall try mine, as I only have 1 key...stupid dealership!
Old Apr 30, 2006 | 10:23 PM
xyrcncp's Avatar
What you need
1...your new key
Thanks man, I'll give it a try once I get my key.
Old May 1, 2006 | 12:56 AM
Topher707's Avatar
05 Acura TL: a-spec
someone let me know if this works...
Old May 1, 2006 | 09:11 AM
Billy Sacco's Avatar
Kilos of yayo in
What you need
1...your new key
So does this program the key or does it disable the immobilizer?
Old May 1, 2006 | 09:15 AM
fsttyms1's Avatar
Key
Old May 1, 2006 | 09:18 AM
SwampGas's Avatar
/etc/car
Does that actually program the key itself or does it just teach the car to accept that key in addition to the already authorized key?
Old May 1, 2006 | 09:24 AM
fsttyms1's Avatar
?? thats just the instructions i found. Id assume that it teaches the ecu to work with the key, or gets the key on the right code?? Either way those are the instructions given
Old May 1, 2006 | 10:09 AM
SwampGas's Avatar
/etc/car
I think the car just accepts that new key...I find it difficult to believe the car is capable of rewriting the RFID in the key, although I'm sure the stores have the capability to write it to the key.
Old May 1, 2006 | 10:43 AM
fsttyms1's Avatar
My depot doesnt have the ability to do it
Old May 1, 2006 | 03:00 PM
tim'sTLS's Avatar
I personnally think you should get your key at the acura dealership. I got mine programmed and cut for about $35.I gave him the vin from my registration and ID for security of themselves and he cut and program the key.The parts guy came out and made sure the car started and everything.And you get an original.(Sierra Acura Alhambra).
Old Jun 22, 2006 | 04:28 PM
LudEcrous777's Avatar
does this way of programming a key actually work? has anybody tried it yet?
Old Nov 10, 2009 | 12:06 AM
amg2y's Avatar
I tried to do the step above, but it didn't work.
Am I missing some thing?
Is there specific timing when I need to step on the gas or brake? Brake pedal become hard after a few pumps.
Anyone tried this and successful? Please let me know. Thank you.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
LoneRonin
Sep 28, 2015 09:11 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
