Need help w/ Fog Light Mod
trust me bro i was the same way....finally i said F* it, and went ahead and did it..but i learned the hard way....i turned my car on without having anything put back together and i got the "SRS" light and had to reset it...
I think the DIY uses wire taps so you won't be cutting into the car's wires
I'd help you out if you were local
much appreciated Handy, I posted a thread in the regional hopefully I'll find a fellow AZ'er out there close enough to lend a hand but if not I'll most likely just suck it up and go in on my own.
our fogs are good as far as being widely spread out...if u put 8K then they dont really serve a purpose...it will be more for looks and if u have 8K in ur fogs and 6K in ur heads then that will look a lil off...
the HID bulbs come along with the kit...its very simple..plug and play...instead of pluggin the harness to the original bulb u plug it into the ballast that runs the new system...then u place the bulb in place like the OEM one and voila...there u have it...HID fogs...
you lost me Zee,
The plug n play come all together...that much I know. the bulb and all come attached and all u do is place the light where u want it...but you can't change the bulb like you can with the factory HID's.
so in order to go with the yellow (3k's) I would have to buy a whole new p'n'p set...right?
If you already have HIDs in your fogs then you only have to buy bulbs.
If you have Xenon plug n' play bulbs then you need to buy a whole HID kit.
An HID kit consists of the bulbs and ballasts. They also come with zipties and wire tappers that help with some installations.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
oyayjoe
Sep 12, 2015 04:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
.....either color match them with ur heads or go 3K becuz that shiet will look
.....uuummm......
.....that icon means "rice"....
...3k is a yellow light and helps cut thru the fog and snow...looks like this..
....if u dont have HID's in the fogs yet you have to buy the whole set which is only like 60 shipped from Egay...look up "9006 HID 3K"
