Need help from somebody with Helm manual
I am trying to find out what friction area of front brake pads on 2gen CL.
Can some body with Helm manual tell me the spec?
It should be in specification chapter under design specification.
Thank you
Thank you
hey fsttyms1 I'm trying to hardwire my V1 radar detector can you possibly scan or take a digital pic of the drivers side fuse box wiring diagram in the helms manual. I gotto know which color wire and fuse goes to the cigerette lighter.
hook it to the back side of the drivers side fuse panel. there is a spot (lower left) thats an accessory optional conector. its conected to fuse #8 all it takes to wire to it is a female spade conector
any way you can scan that page of the helms that shows a wiring diagram of the drivers side fuse box that shows what fuses go to which items and the colors of the wire that correspond with it?
the back side its reall easy. you can see it from looking under the dash, or by removing the lower dash panel (1 screw) its a spade conector. All it takes is a female spade to conect to it)
yea fsttyms1 I hardwired my Valentine 1 last night and it works perfectly. Only wire you barely see is the wire going from the right side of the detector up to the headliner. And I snaked that wire inbetween the 2 suction cups. Looks cool. Due to the angle of our windshield and the placement of our rear view mirror, I mounted the detector centered underneith the rear view mirror as high as possible but where the rear-redar piece of the detector can see out my rear window without obstructing it's view. Looks cool.
Just to clarify, you want to connect the female spade connector to #27 and not #26 (which has red highlight around it). I'm a complete newbie on this but I want to hardwire my sirius receivers 12v power lead. It sounds like I can connect it directly to #27. Can I just connect the ground lead to anything that's metal in the area?
Originally Posted by sluudog
Is there a 5v connection there as well? I have a TomTom GPS unit that I would like to hard wire to the care that requires a 5v power source.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
