Need help with rolling code for the garage!!!
I am trying to program the homelink transmitter in my TL to open my garage door but I found out that my garage door has a rolling code. I can't find my manual so can someone help me out here?
TIA
TIA
Re: trianing mode
Originally posted by Kegrun
On the actual garage door opener there is a button called training. Push that button and it will work.
Late,
kegrun
Late,
kegrun
Okay, what I remember you need to do, is first grab a garage door opener for that garage door that works. Next, reset the homelink by pressing both the outside buttons for more than 20 sec till the light flashes slow I believe or changes its speed. It is more than 20 sec though you must hold it for. Next, once its reset, press the garage door opener open and close button and hold it down, and now push the home link button you wish to use (I use the one with the house on it for me). You should see it change the way it blinks, let go after that. Once that is done, you need 2 people for this part.
Have someone in the car ready to push the homelink button you just programmed, have another person next to the actual garage door unit to press the program button on the side. First press the program button. light should either blink or light up on the garage door, have that person immediately push the home link light, once hte garage door responds it got it, let go both. Do not hold the garage door one more than 5-7 sec or it will reset all your transmitter codes. This worked on our CraftsMan Opener.
re: training mode
yeah it is just like Speedy3.2CL-S said. i just did this last saturday. you will definatly need two people for the last part. i have a craftsman opener as well. if you can't follow what he wrote, this is also in the FAQ's section, but the part about run like hell didn't work for me.
