Need help pinpointing the source of this leak!!
After tightening some loose bolts I noticed this leak! I'm going to clean it up and see if it comes back. I'll check also the pcv to make sure it's not blocked!
It looks like 1 of 2 options. 1 easiest power steering pump gasket seeping. 2 leaking from loose intake manifold cover. Cure? make sure that area on top of pump is spotless, side of intake manifold is spotless, no oil or grease anywhere around. Make sure bolts on intake cover are tight to specs. then drive it for a short while then check if nothing visible drive it alittle further. after a day if nothing visible it must have been the intake. Because the powersteering is under pressure and leaks will be visible within 24 hrs. Hope this helps
rboller
Sep 23, 2015 02:49 PM
