Need help with my fogs
Old Oct 29, 2010 | 06:53 PM
BrooklnzBadB0y's Avatar
Hello everyone, first time posting here.. I have a 02 Acura tl-s
So I was installing a new set of HIDs in my fogs and I connected one side and it turned on then when I connected the other side both sides didnt turn on. I tried the regular fog bulbs(which worked before all this) and they didn't turn on either. The fuse is good so I don't know what it can be.
Any help would be really appreciated. Thanks
Old Oct 29, 2010 | 08:00 PM
FirePR2002's Avatar
bringin lead
you have to reverse the polarity on the passenger side - did you do this. am i reading correctly that you plugged the halogen bulbs in to the pigtails coming out of the ballast?
Old Oct 29, 2010 | 08:32 PM
I already tried reversing the polarity. And the halogen bulbs I put them in the fog pigtails not the ballast
Old Oct 31, 2010 | 03:02 AM
02TL4ATL's Avatar
what fuse did you check? my fogs arent working as well.
Old Oct 31, 2010 | 03:20 PM
I checked the one under the hood passenger side, it says Fog light on the fuse box cover... Does the little light on the fogs button turn on or no? mine doesn't either
Old Oct 31, 2010 | 04:01 PM
02TL4ATL's Avatar
yea the light on the fog light button is still on for mines.
Old Oct 31, 2010 | 04:48 PM
02TL4ATL's Avatar
my fuse box under the hood passenger side doesnt say foglight
Old Oct 31, 2010 | 08:22 PM
It's on the top, it's a 20A blue square fuse
Old Oct 31, 2010 | 08:40 PM
02TL4ATL's Avatar
awesome, thanks for the help, my fogs work again. for the location on the panel it only said tcs thats why i didnt know it was for the fogs. hopefully you can fixed your fogs to.
Old Nov 1, 2010 | 11:11 AM
Your welcome, now let's see if anyone has any ideas on what to do
Old Nov 1, 2010 | 02:59 PM
Ok so I bought a new fuse and the halogen bulbs turned on, but I tried the HIDs and it blew the fuse again! Does anyone know of a relay or something I could use to stop it from blowing the fuse?
Old Nov 1, 2010 | 03:05 PM
jjashaa's Avatar
Avant Garde Wheels
your fuse shouldn't be blowing out if you have everything plugged in correctly
try doing it again with everything off...
Old Nov 1, 2010 | 05:24 PM
I tried everything again and it still don't work!
Old Nov 1, 2010 | 06:49 PM
FirePR2002's Avatar
bringin lead
whats the wattage of the kit you have?
Old Nov 1, 2010 | 07:31 PM
It's the 35 watts kit, should I buy the relay harness from eBay? You think that would work?
Old Nov 2, 2010 | 07:48 AM
FirePR2002's Avatar
bringin lead
something else is going on, you shouldn't be burning fuses with just the install of the kit
Old Nov 2, 2010 | 08:01 AM
TLin401's Avatar
'13 Hyundai Sonata
Where did you get the kit from?
Are you sure that the connection is locked into the harness? Even though you said that you have tried it reverse, stare at it and make sure it is reverse.
You may have defective bulbs.
Old Nov 2, 2010 | 10:59 AM
totaledTL's Avatar
Remove power to both sides (pull fuse, verify w/ meter). Disconnect everything from either driver's or passenger's side. Reconnect power. Does the fuse blow w/ nothing connected? If so you prob. have a short in the vehicle's wiring to one side or the other.
If it doesn't blow, plug in one component only (i. e., the pass. side ballast), restore power and see if the fuse then blows. If not, remove power & then connect the bulb to the ballast you have connected & restore power. Continue in this manner until you isolate the problem, one component/section at a time, one side at a time.
Old Nov 2, 2010 | 07:34 PM
I got the kit from HIDextra, I will try it again tomorrow
Old Nov 2, 2010 | 08:45 PM
totaledTL's Avatar
Avenger411
Oct 11, 2015 03:53 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
