Need Help With Mesh Grill Mod!!!!!
99TL-p 114K
I tried cutting one sheet of the mesh to the shape of the grill, but im having trouble on how to fit it in. Should i cut out the "A" symbol in the middle of the mesh or should i just put a sheet of mesh right over the top and just cut the shape of the grill and put the A symbol right over it? THIS IS A PAIN IN THE ASS. ANY SUGGESTIONS???????????
take the chrome strip off along with the A then after the gutter guard reattach if you want or just the A
Graphic/Web Designer
Originally Posted by TLEXTREME
i did it in 2 hrs with one hand but i bought the cheap crap just to see what it would look like.
Damn, I had a hell of a time doing it with two hands, let alone one.
2400 Watts in a TL...Why?
1 Post
Take off all the chrome and then...
Use cardboard and cut it to fit the grille then trace the desgin onto the mesh.... You'll cut the crap out of your hands if you need to remove and refit the cut piece, those damn things get sharp once they are cut.
Enjoy..
99TL-p 114K
My Exact Problem!!!!!!!!!!!!!!!!!!!!!!!!!
Ok, Mesh Has Been Cut To The Shape Of The Grill Ok. Problem Is, Should I Cut The Shape Of The "a" Symbol Out Of The Mesh Or Not? I Guess I Have To, To Make The Chrome Piece Close Down Allllll The Way So That I Can Be Able To Put The Screws Back In. I Dont Know What I Should Do Cuz I Want Mesh To Be Behind The "a" Symbol Instead Of Just Meah Grill With Black Plastic Hind The "a" Understand??? Any Suggestions??????????????????????????????????????? ?????????????
1 Post
Yes, cut the mesh and allow it to push flat against the back.. You'll end up cutting an oval instead of a circle for the "A" to fit in. Don't worry it'll all be covered by the chrome.
i know exactly where you are now, keep truckin through, you'll be done soon.
I would take theactual "A" off and put alittle bitof mesh behind the "A".. It looks really good IMO.
99TL-p 114K
Stage 2 complete
Aight, i cut the shape of the "A" symbol out of the grill shapped piece of mesh. It fits just fine. Now, i also cut a small piece of mesh to put behind the "A" symbol. What i want to kno now is am i supposed to cut the shape of the other chrome piece that the "A" symbol attaches to, out of the already cut mesh??? You kno, the chrome wing shapped piece, am i supposed to aslo cut that shape outta the Mesh so that i can put the "A" symbol on the wing thing, and the wing thing screwed back to the entire grill????
99TL-p 114K
Here Are The Pics Of What I Was Talkin About
Here are the pics. Now is it supposed to be like the first two pics, or am i supposed to also cut the shape of the chrome wing piece outta the mesh as well so that it looks like the third pic? If its supposed to be like the third pic, then am i supposed to cut the shape of where that winged chrome piece goes so that it can go right up against where you screw it in?
99TL-p 114K
Pic 1
Pic 2
Pic 3
Pic 1
Pic 2
Pic 3
1 Post
Unfortunately, I would suggest pulliung it apart and painting it chrome if you want to keep it that colour. Simlpy because I had that exact grille on my 99TL... after a few months something bled from the mesh onto the chrome and it was really hard to get off.
Now I'm working on a mesh for my new TLS, I have bought a can of clearcoat and a can of chrome paint.... both from teh spray paint section of Home Depot.. the paint is indoor/outdoor paint for metal.
I've cut the mesh for the lower front lip, fit it to the car, then I'm giving it a couple of coats of chrome paint and then a coat or two of clear. i don't expect it'll change the appearanceof the mesh but it'll prevent the mesh from loosing it's shine and going flat grey.
99TL-p 114K
Stage 3
In the painting process right now. Just primed it with some Rustoleum Primer. That spray paint is good cuz it prevents rust. Then ima paint it black. It should turn out nice. One thing i noticed though was that the mesh doesnt exactly lay in there perfectly flat does it? It kinda slopes inward from the outside cuz its held tight on the edges and that the center wing piece adds pressure to it causing the mesh to slightly slant inwards. Idk, doesnt look bad or anything, but was just wondering if thats the way it always comes out? Notice that i cut the entire shape of the wing piece. I got pist and just cut the whole shape out. LOL Its hidden though buy the chrome wing.
99TL-p 114K
Originally Posted by RelentlessOne
Somebody correct me if I am wrong, but you don't need to worry about rust because the GutterGuard is aluminum, which to my knowledge doesn't rust. Have you tried removing the oval piece of mesh behind the A? I think having the black show through would give it some nice contrast. Anyway, good work.
I guess it is aluminum. IDK, whichever it is, just to be on the safe side, some nice primer and coat of rustoleum black semi glossy should seal good. What oval piece are you talking about. If you see in that first pic above this where i have both mesh pieces i cut out, is that little piece of mesh i cut thats going behind the "A" the oval piece of mesh your talking about? I dont understand.
99TL-p 114K
I do like the way the mesh looks plain silver on the car but i think the black mesh would look better with my Silver TL. But yeah, i gotta wait till tonight before i put it back together. That paint is still kinda sticky. I gotta let it thorougly dry before i put it back together. Anyways, ill post pics when its all installed and done. Later.
99TL-p 114K
All Done! Success!
I finally finished, it dried up pretty good and i installed everything back together with the new black mesh in the grill. LOOKS NICE. Ill post final result pics tommorow. Too lazy to take them now plus its already night time. Later.
quanaman
01-09-2023 07:33 PM
InFaMouSLink
10-27-2015 06:52 PM
