Need help finding part for foglight switch
Old Dec 12, 2011 | 09:48 PM
simran4h's Avatar
i have a 02 tls and when i was cutting and trying to connect the 2 wires from the foglight switch i cut them to short and messed it up.........does anyone what the white plug tht goes into the foglight switch is called and i need the wires to come with it......thanks
Old Dec 12, 2011 | 11:07 PM
Karanx7's Avatar
Unregistered Member
I don't think you can buy just the wire plug itself. They might only sell the entire wire harness for the area. That would be ~150 dollars.
Old Dec 13, 2011 | 01:37 AM
sammy95's Avatar
Might be able to get away with it by finding female spades at an electrical place and just plug them in.
Or maybe someone here has an old harness laying around. Anyone?
Old Dec 13, 2011 | 10:52 AM
01tl4tl's Avatar
an auto electrical specialty shop will have- or quickly make you- a new connector with wire leads coming off it,,they have bins full of every type connector
solder the old wires to new and cover everything with shrink wrap,
or the less preferred method of using inline or butt connectors
Old Dec 13, 2011 | 11:17 AM
totaledTL's Avatar
What Karanx7 said... sounds like you're describing part of the wire harness, not the switch, unless it has a pigtail. If so you most likely would have to buy the switch assy. Or visit a junkyard to harvest the plug then splice it to your harness.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
PortlandRL
Sep 14, 2015 12:01 PM
