Need help with a check engine code.
Old Aug 5, 2004 | 08:50 PM
fsttyms1's Avatar
i have a check engine light on and it comes up with a P0401. (Insufficiant egr flow. needs egr ports cleaned)
does any one know what the servicing of this code reqires? ie...what do i have to do to fix this? take apart the intake??? any instructions would be appreaciated.
Old Aug 5, 2004 | 09:40 PM
TLMugen's Avatar
I'd rather be driving:
According to the service manual:
1. Reset the PCM
2. Test drive under the following conditions:
- Without any electrical load
- Decelerate from 55 mph (88 km/h) for at least 5 sec.
3. Check the Temporary DTC with the scan tool.
Is Temporary DTC P0401 indicated?
YES - Clean the intake manifold EGR port with carburetor cleaner. Clean the passage inside the EGR valve with carburetor cleaner or replace the EGR valve.
NO - Intermittent failure, go to step 3.
4. Turn the ignition switch OFF.
5. Disconnect the EGR valve 6P connector.
6. Connect the battery positive terminal to EGR valve connector terminal No. 4.
7. Start the engine and let it idle, then connect the battery negative terminal to EGR valve connector terminal No. 6.
Did the engine stall or run rough?
YES - Intermittent failure, system is OK at this time.
NO - Clean the intake manifold EGR port with carburetor cleaner. Clean the passage inside the EGR valve with carburetor cleaner or replace the EGR valve.
Old Aug 5, 2004 | 10:19 PM
fsttyms1's Avatar
thanks!
oh, does it say i need to remove the intake manifold to do any of the cleaning?
Old Aug 6, 2004 | 08:20 PM
fsttyms1's Avatar
here are a few picks of why i was getting the code. the 2nd
2 last picture is just a little bit of what i pulled out of the first 2 pics.
Old Aug 6, 2004 | 09:10 PM
TLMugen's Avatar
The quote I posted was the whole entry in the manual under DTC P0401. It says clean the EGR ports but it doesn't go into detail about how to do that in that section. I guess you're addressing it effectively anyway, the carbon build-up is probably what's giving you the code. Nice pics! I always wanted to know what was under that engine plate. Give us an update if this solved the code or not. Glad I could be of some help.
Old Aug 6, 2004 | 09:19 PM
fsttyms1's Avatar
oh yea forgot to add the light went off.
thanx again for the help
Old Aug 6, 2004 | 09:22 PM
Street Spirit's Avatar
Wanna come do that for my car too?! :P No 'check engine' light in my case - but just so amazed at how much cleaner you've gotten it!
Old Aug 7, 2004 | 01:04 AM
fsttyms1's Avatar
yea after opening it up and seeing that crap all built up! i was like holy $hit! well its alot smoother running. and for most it would be a Very easy job. just unbolt the 10 or so bolts and pop the upper cover off to see if they have the build up. this is my 2nd time with this issue (its a known issue with honda because they have a kit to help eliminate the problem) 1 hour of your time and a cn of carb cleaner and you can clean the upper cover your self!
oh and to answer your Question. if you came to me id help ya clean it!
Old Aug 7, 2004 | 09:04 AM
oh yeah --- is it really noticeable how much smoother the car runs? am seriously considering looking into this on my '99. what product did you use to clean it?
you'd help me out, eh?! ....hmmm...better start driving NOW!
Old Aug 7, 2004 | 09:34 AM
benzo555's Avatar
boo
WOW! I hate to see what mine looks like.. :sqnteek:
Old Aug 7, 2004 | 09:48 AM
fsttyms1's Avatar
i just used gunk carb cleaner in a spray can (well 3 bottles worth) yea its smoother idleing and the power seems to be better (after cleaning the whole intake)
Old Aug 7, 2004 | 10:02 AM
k... will head to the store to get some today... hoping i can clean mine too (if it needs it)
Old Aug 9, 2004 | 09:17 AM
fsttyms1's Avatar
you will find out as soon as you pop the top plate off
Old Aug 9, 2004 | 11:53 AM
jpadilla's Avatar
What year is your car? I assume its out of warranty since you are checking the codes yourself instead of the dealer ... I had my EGR ports cleaned by the dealer, they said it was a know issue and did it as warranty work. Unfortuanatly that did not take care of my issue. My issue is that it feels like a hicup when I crusing at 40mph. I now pass it off as my car deciding what gear to use at that speed.
Old Aug 9, 2004 | 02:37 PM
hzm82's Avatar
He has like 150k+ miles on it so he's out or warranty.
Old Aug 9, 2004 | 07:05 PM
Southern's Avatar
"2 last picture is just a little bit of what i pulled out of the first 2 pics."
Looks like the inside of my grill. Great illustration & explaination.
Years ago my 79 Toronado intake manifold looked like that. I sprayed it with oven cleaner, let it sit overnight, and hosed it off the next day. Looked like new.
Old Sep 14, 2004 | 01:57 AM
Wow..this is a very helpful thread. My car idles kinda rough in the morning...I'm thinking about doing this too. Do I need to drain the oil before doing this procedure? Any other advice/info before I do this? It was easy to take out the bolts right?
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
