need help!! Asap
Old Sep 16, 2008 | 03:41 PM
nguyen's Avatar
need help!! Asap
Okay I'm stuck in houston and I got no electricity
I didnt drive my car before and after IKE hit
but now when I turn on my car the rpm goes up and down
I did a search and found that it is because of the IACV or watever
So does anyone have a DIY with pictures and step by step
Also does driving around like this affect my car in any bad way
Need help
Old Sep 16, 2008 | 05:57 PM
fsttyms1's Avatar
Look at the bottom of the TB. There is a small device held on with 2 philps screws that hold it on. Remove them (helps having a stubby screw driver) then with some carb cleaner or sea foam and old tooth brush clean it.
Driving shouldnt hurt it but will be difficult to drive in that condition. Also just simply driving it may help clear it up but i would still clean it. When done cleaning apply a small amount of WD40 to it to help keep it lubricated.
Old Sep 16, 2008 | 07:57 PM
ProjectTLS's Avatar
o.O
my beloved hometown
Old Sep 16, 2008 | 09:25 PM
TX-Miner's Avatar
Need help
Nguyen,
If you want to make a road trip down the coast, I can give you a hand changing it out. We have electricity and A/C here. I good 200 mile drive might be extra good for cleaning out the carbon and get your mind off Houston.
Miner
Old Sep 17, 2008 | 03:40 PM
nguyen's Avatar
ok i fixed the idle problem but now im left with both vsa lights on
the one in the rpm dash and the one with the exclamation mark
how do i fix this!!
Old Sep 17, 2008 | 04:25 PM
nguyen's Avatar
also sometimes wen im at a stop i feel my car drop below 500 rpm n the car shakes but then it goes back up to 750-800ish
i mite have touch the throttle cable or soemthin is there a fix for this
Old Sep 18, 2008 | 09:57 PM
3.2TLc's Avatar
If your EGR passageways are restricted, it can also cause a poor idle or even stalling. Just something to check if still having problems.
Old Sep 19, 2008 | 06:55 AM
fsttyms1's Avatar
Did you disconnect the battery? You didnt do anything to the throttle cables. Your VSA light, Are you sure every thing is plugged in. Go back and double check. Check the VSA throttle body (the one before the TB). Also try resetting the ECU by pulling the clock backup fuse
Old Sep 19, 2008 | 12:47 PM
swalch@stanford.edu's Avatar
I was interested in this comment because I want to clean the bleed valve on a Honda Civic. So carb cleaner is OK for that and it is good to lube it with a little WD40 afterwards? That was what I was going to do but wanted to be sure I wouldn't damage the electrical part of it. From the drawing of the part in the manual it looks like the valve part is separate from the solenoid portion, so it should be OK.
Old Sep 19, 2008 | 12:55 PM
fsttyms1's Avatar
yes its separated, and i got the tip from 2 other acura mechanics.
Old Sep 19, 2008 | 09:47 PM
nguyen's Avatar
i disconnected the battery n double checked everything and the lights are still on
i will try the fuse one tomorrow to see if i have any luck
Old Sep 19, 2008 | 09:50 PM
NighthawkBlack's Avatar
Need help
Before you go crazy with testing and idle control valave swaps, get a can of seafoam for the intake. How long did your car sit? WHen I did my timing belt and 100k service I had my car down for 3 weeks. Same symtooms, went crazy thinking vacumn leak, IAVC etc. Turns out it just needed seafoam after I took the thing apart twiceand changed gaskets. Dont mess with the idle setting until you try the seafoam. How did you fix the idle fluctuation when you said you fixed it?
Old Sep 21, 2008 | 11:18 AM
nguyen's Avatar
still no luck, both vsa lights are still on
i did the battery, rechecked to see if everything was plugged in, and pulled the backup fuse
do u have a pic of what the VSA throttle body looks like?
what should i doooo
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
