need help with alignment readings
Old Jan 13, 2002 | 10:57 PM
erik's Avatar
here are the specs;
FRONT
camber front left / front right
before: -0.1 / -0.6
actual: -0.3 / -0.6
total toe front left / front right
before: -0.47 / -0.55
actual: -0.01 / 0.1
cross camber front
before: 0.5
actual: 0.4
front total toe
before: -1.02
actual: 0.00
REAR
camber rear left / rear right
before: -1.2 / -1.4
actual: -1.3 / -1.4
total toe rear left / rear right
before: -0.07 / 0.08
actual: 0.03 / 0.6
rear total toe / thrust angle
before: -0.03 / -0.05
actual: 0.14 / 0.01
my fronts are fine but my rear wheels? rears are butterfly i think, not sure though does this mean i need a rear camber kit only?
Old Jan 13, 2002 | 11:17 PM
AcuraTL's Avatar
OG
What springs do you have? Everything looks fine except for the rear camber. I would say you are on the border line of needing a camber kit. You should be ok. If it was the front, you would definitely need a camber kit.
Old Jan 13, 2002 | 11:48 PM
erik's Avatar
comptech springs installed about a 1.5 years.
Old Jan 14, 2002 | 12:24 AM
AcuraTL's Avatar
OG
Do you have a stereo system in your trunk?
Old Jan 14, 2002 | 11:50 AM
erik's Avatar
i have 2 subs enclosed box, ~45lbs total. didn't have a camber problem in the back when i first had it lowered. could it possibly be that over time; it just settles too much? i'm gonna install the sways i bought from Jack (blulegend) this week, will that affect alignment too? maybe i'll install the camber kit in the rear at the same time but its friggin $175.
Old Jan 14, 2002 | 06:41 PM
Jens
Guest
Posts: n/a
Installing sways should have no effect on camber whatsoever.The camber readings you have are typical and in all honesty nothing to worry about.These rear camber numbers are about typical for a lowered TL.Unless you are showing excessive tire wear I would not at this time bother with a camber kit.Just remember to up your rotation schedule a bit and you should be fine.Jens
Old Jan 14, 2002 | 08:23 PM
MahaRaja's Avatar
what do you guys think about -1.4 and -1.8 in the rear(measurements taken without system, but i have about a 50 pound system now)?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
