Need help!!!
Old Dec 30, 2008 | 04:17 AM
JDM_UA5's Avatar
Need help!!!
hey you guys i have a 03 ssm TL-S and im having problem, there is a clicking noise coming from the passenger front wheel.. it only clicks when im at a complete stop then when i take of it clicks and when im braking it also clicks.. i was told it was due to blown shocks but not soo sure if you guys have the same problem and was able to figure it out plz help cuz that shit is annoying...thanx
Old Dec 30, 2008 | 07:03 AM
`ill*tl's Avatar
A blown shock makes more of a "squeak-squeak" noise. That ticking noise you hear is most likely a bubble or nail/object in your tire..
Old Dec 30, 2008 | 08:03 AM
JDM_UA5's Avatar
naw its not a nail it really sounds like something is loose on the front passenger suspension juss cant find where its loose from..but thanx for the feedback..
Old Dec 30, 2008 | 08:30 AM
FirePR2002's Avatar
bringin lead
have you inspected the brakes and ball joints (purely a guess on the ball joints)? a pad could possibly be not seated correctly, causing movement in the caliper.
Old Dec 30, 2008 | 09:42 AM
`ill*tl's Avatar
..a blown ball-joint also makes more of a "squeaking" noise rather than a "ticking" noise. I guess its rly hard to determine where+what sound its making.. but if you did your coil install yourself, I'd just go back and re-tighten everything..
Old Dec 30, 2008 | 05:00 PM
spoka's Avatar
Yeah ticking noises that are only noticeable at low speeds are usually solid objects lodged in the tire like a nail or rock
