Need to find 12v power source in engine bay
I need to find a 12v power source in the engine bay. I'm wiring some fog lights and theres a red wire that needs to be placed onto a 12v power source. Any help would be great.
Uhh well I have one at the battery already...It says I need to put one on the positive which i did and then theres another one that says it needs to be placed on a close 12v source
(unless of course, it's the black-colored cable...
then you need to connect to that "other" post on the battery or any other piece of metal in the engine bay)
I dont see how it makes me a n00b if i connected one to the battery already and was wondering what to do with the other one...but anyways I have a new issue. There is a plastic thing that holds the wires and connects to another set and two fo the three ripped out of their places somehow. so i have to somehow get them back into it but it doesnt want to lol
For the two wires that connect to the make/break switch contacts inside the relay, one goes to battery +12V, and the other goes to the foglight bulbs.
For the remaining two wires that connect to the magnetic coil inside the relay, one goes to battery +12V, and the other goes to the on/off toggle switch usually located inside the car. Polarity is important for these two wires because you will hear a click inside the relay if the polarity is correct.
Also, the foglight metal housing and the other contact on the on/off toggle switch must be connected to ground.
Battery
